Author Topic: Choosing a multimeter  (Read 3172 times)
Offline Bailgang
  • Scott
  • Indiana
« on: January 21, 2018, 10:08:31 AM »
Within the past year I've had 3 multimeters fail, 2 were older radio shack analog meters that finally succumbed to water damage from a garage fire I had years ago and a more modern digital meter I bought from a local advance auto parts store a few years ago. Why the newer one failed is still a mystery but I'm down to 1 pocket size digital meter that I've had for close to 30 years now and it's showing it's age. What I'm looking for is a meter that's not outrageously expensive yet is reliable from a long term point of view. I'm not an electronic whiz so the meter doesn't have to have all the bells and whistles yet have enough functions to satisfy my needs. With so many Chinese knock off meters with questionable build quality currently available it's hard to know which meters are actually decent. Fluke is the name that always seems to stand out in regards to quality so would say a model 114, 115 or 117 be the best choice or are there other more reasonably priced yet reliable meters available? Give me some opinions.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
    • http://forums.sohc4.net/index.php?PHPSESSID=g3dpmvvv4j0dtrv2d8el7qvos5&/topic,60973.0.html
Re: Choosing a multimeter
« Reply #1 on: January 21, 2018, 11:01:48 AM »
go for one vho can thek kondensators "farad"units..and have a nice "beeb "funktion for closed/ konneltion test..i use mine too for points adjust....it stoops beeb vhen the gap opens..(.somtimes even vith the kondensator konnekted)..i have just a"biltema" brand. vho does a nice job.but is Money not a issue a fluke is the best ..but for most a good" betveen" preised often do a good job..use it evry day fluke vinns..once a month..all can do the job..just not the low cost ones
http://www.biltema.dk/da/Vaerktoj/Malevarktoj/Maleinstrument/Digitalt-multimeter-DMM-1000-P-2000024201/
« Last Edit: January 22, 2018, 07:55:05 AM by strynboen »
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #2 on: January 21, 2018, 12:19:59 PM »
Eh, I found a Fluke 87 III on Ebay for around $100US and it has worked great for me so far no matter what I have used it for.
Like you said it is hard to find reasonably-priced units so sometimes ya gotta pony up for more quality stuff.
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #3 on: January 22, 2018, 05:17:48 AM »
I have owned a Sears Craftsman multimeter for 20+ years now. Still works perfect.
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
Offline rocket johnny
« Reply #4 on: January 22, 2018, 10:54:31 AM »
don't buy the el cheapo one from freight harbor ,  junk
« Reply #5 on: January 22, 2018, 02:28:31 PM »
The really el cheapo is usually free with a coupon and a minor purchase. Might be OK to have kickin' around a saddlebag.
Offline jgger
« Reply #6 on: January 22, 2018, 05:29:22 PM »
If you get the El cheapo from Harbor Frieght open it up and take out the battery. Throw the rest of it in the trash.
Offline b52bombardier1
« Reply #7 on: January 22, 2018, 06:10:13 PM »
The cheap meters struggle with taking accurate measurements of small values of AC. And this problem hampers its ability to check for diode leakage of AC out to the battery posts.
 For me, I love my Fluke 17B.
Rick
1972 Candy Yellow CL100 K2
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
Offline Tim2005
« Reply #8 on: January 25, 2018, 12:19:24 PM »
Has anyone found any reasonable multimeter leads online (probes and clips options type) online, for those of us who already have a meter of sufficient quality? There seem to be few options between the Fluke/Megger at 50+ per set and the rubbish ones at 2 per set, and it is very hard to tell quality from the pictures.
Offline 2wheels
« Reply #9 on: January 25, 2018, 12:42:16 PM »
I like these
https://ca.mouser.com/ProductDetail/Pomona-Electronics/3782-24-2?qs=sGAEpiMZZMv8kklI404QlVzzwyWt7SCd
I work in electronic repair and use these every day.  10 dollars a piece and mine last more than 10 years now.
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
« Reply #10 on: January 25, 2018, 01:32:37 PM »
megger"s is expensive..and use a lot of battery power.
..but are often a seperate meter mostly for test for leaks to ground.in the elektro motor shop.industri.
.and have the normaly ohm/volt as a sekundery funktion.and the old ones industrial can messuring very low leakings..and ohms differenses in vindings..and low restistens differenses in thik Windings..like starters motors..vho normal ohms just give a full direkt konnektion reading=zero ohm
..but oftens ve dont used them ,,the Scalas vas not optimale..the probes vas a bit streange..
..easyer to grab a normal multimeter...
they are nice to thek sparkplug for shorts..
in a normal shop i dont use them so often..so to bay one..better take the few parts to a shop and get them testet..
Offline Bailgang
  • Scott
  • Indiana
« Reply #11 on: January 25, 2018, 02:52:46 PM »
You guys are awesome, thanks so much for the input. Right now I'm stuck as to exactly what meter I want, do I want a a meter that's primarily designed for electronic use or an automotive type? I'll make up my mind soon .
Scott
71 cb350 twin
77 cb750 F2
Offline 2wheels
« Reply #12 on: January 25, 2018, 04:07:48 PM »
Id buy a used Fluke ,no more than 10 years of normal use, before getting a 50 dollar new one.
« Reply #13 on: January 25, 2018, 04:14:49 PM »
I think if you get one with auto ranging and auto shut off.  You will be happier in the long run.
« Reply #14 on: January 26, 2018, 02:44:18 AM »
auto ranging can blurr the resultats a bit..specily in korodet viring test and old komponents like bikes..make it hard to get it read aut a solid resultat.
i dont like it on old stuff..
.but yes more vork to range  the ohms/volts manuall..
but the meter vill give a varning if yoy take a to lov range..it blows not up..so no harm..just take a new heiger range and try Again..on job ve never took the auto range meters to do test..ve picked the older instruments to that spec job..(auto/industri- elektro rep shop)
« Last Edit: January 26, 2018, 02:45:50 AM by strynboen »
Offline crazypj
  • I'm brill, me
« Reply #15 on: January 26, 2018, 06:10:51 AM »
The '$4.99 or free' 'red one' is pretty bad but OK to leave laying around for 'emergency' checks rather than accurate results. Don't even think about using it for resistance (Ohm) checks though. (even if you open it up it isn't possible to zero / full scale adjust it with the internal 'pot')
 I found the HF POCKET meter in soft vinyl cover damn good and reliable.
 Replacement 12v battery cost at least double what you pay for meter but as it lasted for more than 6 yrs (and didn't leak)so I got a replacement battery as it wasn't in stock (not sure it's even listed nowadays, sometimes they make things real good by accident  ;D)
The only way I found to get decent quality at reasonable price was make my own.
Silver plated copper wire with flexible silicon insulation plus gold plated plugs and probes. Can't remember total cost but way less than $50.00 for 'Lab Quality' leads
« Last Edit: January 26, 2018, 06:19:39 AM by crazypj »
Offline 2wheels
« Last Edit: January 28, 2018, 07:25:43 AM by strynboen »
Offline crazypj
  • I'm brill, me
« Reply #18 on: February 02, 2018, 06:11:07 PM »
 It is, I got a HF coupon freebie today. Haven't taken it out of package yet, Will test it on known settings/components next week sometime
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #19 on: February 03, 2018, 03:28:21 AM »
I have LOTS of the HF freebies laying around, I find they are very useful for voltage checking, or continuity checks... now as far as accurate, the Ohm readings are off a little as compared to my Fluke or my other HF expensive meter, but they work well enough to keep one everywhere. And as the "Price Is Right", Come on Down!! If they malfunction, keep the leads, and throw it away...
Oh, and my old Fluke 87 display just faded away, one digit at a time, until no longer readable...
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
« Reply #20 on: February 03, 2018, 04:05:57 PM »
Charlie
I did the same thing.  For accurate work I use my Fluke meters.  I must have 10 of those HF freebies stashed about.  One of them broke just pressing the included leads into the face!
You know, you can repair your Fluke by replacing the display module.  Just sayin'.
https://www.ebay.com/i/332285552148?chn=ps
Offline Bailgang
  • Scott
  • Indiana
« Reply #21 on: February 04, 2018, 11:05:34 AM »
I ended up settling with a Mac Tools EM710. I hope I made the right choice for my applications and hopefully it lasts longer than the previous Actron meter I purchased from my local auto parts store.
Scott
71 cb350 twin
77 cb750 F2
Offline jgger
« Reply #22 on: February 04, 2018, 11:32:48 AM »
Meters are easy to find, I'm wondering where in the HE-double tooth picks did you find a Mac dealer?
I have a busted end wrench and a ratchet that needs a rebuild and can't find a dealer anywhere.
Offline Bailgang
  • Scott
  • Indiana
« Reply #23 on: February 04, 2018, 01:37:44 PM »
Got it off ebay
Scott
71 cb350 twin
77 cb750 F2
Offline Jore
« Reply #24 on: February 04, 2018, 08:13:52 PM »
There's a china only Fluke that AvE reviewed some time ago, you can get them for less than 100 dollars allegedly.
That said, last time I was in the us I wondered in to a harbor freight and almost bought an automotive multimeter they have for 30 bucks, according to the website it has all these functions:
This automotive multimeter allows you to measure AC/DC voltage, dwell angle and engine RPM. With the large easy-to-read LCD display, readings are clearly visible even in low-light settings. Functions on this automotive multimeter include diode test, HFT auto range, resistance measurement, capacitor test, Ohm, tach, low battery, auto zero, continuity and temperature.
Tests AC/DC voltage, DC current, resistance, frequency (Hz), continuity, diode, transistor, temperature, dwell angle and RPM (tachometer)
Large easy-to-read LCD display
Accurately measure dwell angle and engine RPM on 3, 4, 5, 6, and 8 cylinder engines
Read temperatures from -4° to 1382° F (-20° to 750° C)
Audible continuity indicator
Over range indicator
Data hold
Low battery indicator
Auto-off
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
