Author Topic: Cb550 cafe/brat rest/mod  (Read 2888 times)
Offline work9to5
« on: January 28, 2018, 05:34:16 PM »
Hi guys, this is one of the bikes I’m biulding at the moment. It’s actually my original vintage bike (or at least the frame and bottom end is) that I purchased 9 years ago. She’s been through it all, a lot of good times and good rides, and a lot of sitting neglected in the corner while I work on other people’s bikes or just other things. Well she’s been sitting for about three years currently and I’m gonna change that.
So far-
1.) gsrx750 front end conversion
2.) cb650 swingarm and rear wheel conversion
3.) cl360 headlight and mounts
4.) tip end rebuilt, cb650 cam, standard bore
5.) hooped and de-tabbed
6.) built a 4 into 4 exhaust system using the stock headers, some ingenuity and some reverse cone mufflers
7.) “pill style” oil tank which I welded up to serve as a battery box
8.) cb200 gas tank
It’s a pretty awesome looking build. Still really rough, but she’s up and rolling and fires.
« Last Edit: January 28, 2018, 11:42:18 PM by work9to5 »
Re: Cb550 cafe/brat rest/mod
« Reply #1 on: January 28, 2018, 09:44:30 PM »
Why did you choose to use a 650 wheel?  I assume you are not keeping the dirt front tire??
Offline work9to5
« Reply #2 on: January 28, 2018, 11:33:49 PM »
I choose the cb650 rear to keep the bike even stance wise. Shorter fork up front as well as a smaller diameter wheel I had to compensate without going to smaller rear shocks. I couldn’t use smaller rear shocks because I was worried the hooped rear end would bottom out on the tire. So I used the cb650 16” wheel and 1” larger than stock rear shocks. It retains the stock stance/rake/handling of the cb550 estenially, it’s just lower to the ground. Also I think it just looks better having the mag in the front and comstar in the back. It’s something I’ve done before. I’ll post a pic of my daily (which btw is for sale $4k and has some engine goodies hidden in there).
The front tire is tkc80. It’s the same tire that comes stock on gs1200. It’s awesome and I’m definitely/defiantly keeping it.
« Last Edit: January 28, 2018, 11:39:21 PM by work9to5 »
Offline work9to5
« Reply #3 on: January 29, 2018, 08:50:00 AM »
Guys, I understand what rake and trail are. I appreciate it Calj but neither of these bikes are twitchy. Now, the other build I have going on, she’s twitchy af.
Anyways...I got tuned to a point where I was excited and comfortable enough to put a chain on her and roll her down to the street. Gotta do some clutch adjustment. She started “baby stepping” with the clutch held in. Which I didn’t look at as a totally bad thing at least she wanted to go. But unfortunately when I shift from neutral to either 1st/2end she would die on me. So either I’ve got stuck clutch plates, the clutch is WAY out of adjustment or possibly the battery being so low from messing around all day tuning was throwing it off. Gonna get back in there today and see if I can get my first ride down the block! I may fab and stitch the seat as well. Wish me luck!
Offline work9to5
« Reply #4 on: January 29, 2018, 10:04:17 AM »
I measured everything on the first one. I’ll do measurements in this on this one today and post up the results. I expect them to be different between my two gsxr forked bikes. I’ll also do it on my bobber build just for sh&; and giggles.
I’ve had these type of rake/trail convos often in the past year. I became friends with a group of sport bike riders who track occasionally. They get so worked up about these suspension changes to their bikes (even though none of them probably own a wrench). Ive asked one of them recently after he raised the back of his bike “well does it feel better”, does it make you more comfortable on your bike so that you can corner with more confidence and enjoy it more. He responded “no, but it’s the correct rake and trail for a track bike. That kinda stuff drives me nutz
Offline work9to5
« Reply #5 on: January 29, 2018, 03:51:05 PM »
Ok! Took around the block a dozen times! Tiny leaks from tapper covers and there a blank spot right at 1/4 throttle. One other thing is as soon as I turned the key after riding around the block the battery went from 12.7 to 10.4 immediately. Any idea what would cause that big of a drain? (Head light is not attached currently). It’s only a basic wire right now so I’ll find it when I do the final wire but a point in the right direction would help.
Ok trail 3.9” on this one
On my daily it’s 3.75
On my ridiculous 70’s bobber build (standard forks) which is “twitchy as f”, looks super cool but is basically an advanced rider course all in its self is 2.9”
I don’t have an angle finder (someday 🙁) is cant accurately measure rake degree
Offline work9to5
« Reply #6 on: January 29, 2018, 03:59:50 PM »
Pics of each in order of listing
Offline work9to5
« Reply #7 on: January 29, 2018, 04:02:03 PM »
For some reason I can’t upload more than one photo at a time
Offline work9to5
« Reply #8 on: January 29, 2018, 04:02:54 PM »
70’s bobber
Offline work9to5
« Reply #9 on: January 29, 2018, 07:35:52 PM »
That was my first thought (battery) as well. It’s brand new and I havnt cranked on it. I switched in a different batter, same result. It maybe that it’s a tiny battery...true gel MG4L-BS. I’m not worried about it so much as I’ve got leads hanging for the non-essentials and havnt covered and soldered every connection. I’m going to take most off it out and start from scratch anyways now that the engines up and tuned.
Does 3.9 sound off for some reason? This one does “sit” differently than my daily. It’s lower to the ground and seems easier to roll around the garage a bit lol. I should mention that they are different years forks/triples 97’/01’
Finished the seat pan just now and drilled it out for rivets and mounts. My next post I’ll do a step by step on sewing/making the seat. I’m going to try to get the tuck n roll pleating to match the cb200 tank pad so it’s a bit more “consistent” tank to tail.
« Last Edit: January 29, 2018, 11:24:17 PM by work9to5 »
Offline MetroRedneck
« Reply #10 on: January 29, 2018, 08:49:31 PM »
Trail should be around 4.51” depending on your tire - that’s about what I have calculated with a 23.6” (120/70 17) tire and gixxer forks. The higher the number the twitchy-er it will be. As you bring the forks closer to the stem, the trail increases all other things the same.  The CB550 has about a 26 degree steering head angle.  To decrease you can play with tire sizes and fork length to adjust head angle to the road.
« Last Edit: January 29, 2018, 08:58:28 PM by MetroRedneck »
« Reply #11 on: January 30, 2018, 06:05:25 AM »
That's a better trail number than the stock CB, using less offset forks. That sounds odd to me. What is the offset on that year GSXR? From your pictures, it looks very small.
It's probably around 1.125".  That's what my 06 is, and I doubt they moved much looking at pics of the earlier years.
« Reply #12 on: January 30, 2018, 06:52:18 AM »
Trail of a cb550K with a GSXR triple and fork length is 4.51".  That's mine using a calculator and running a 120/70 17 and stock gixxer fork length and my measured offset - which is not super accurate, but close enough.
« Last Edit: January 30, 2018, 06:56:20 AM by MetroRedneck »
Offline work9to5
« Reply #13 on: January 30, 2018, 08:53:41 AM »
Ok guys, even though this convo is boring as hell to me I’m going to indulge you. There can not be a standard “set in stone” number for trail. Even sitting on a bike can change its trail. I’ve done more than just sit on them. I changed rear rim size, changed rear shock size, changed swingarms. Even between these two bikes there’s a difference in ground height clearance (I’ll try to get a picture before I leave for work of them sitting next to each other to show the difference. I didn’t measure super accurately, I just used a steel rod and a 90 but I did not manipulate the numbers.
« Reply #14 on: January 30, 2018, 08:59:09 AM »
I am re-purposing the factory damper.  Waiting on a tube clamp to come in.  With the way I am doing my headlight, there is not enough room to use the factory mounting location.
I don't think it's going to matter much for me though - At 6'2" and 200 pounds, I don't plan on going hard through any twisties in the bayou flat lands with the anemic 550 that might put down 35 horse with a tail wind - that's what my 848 streetfighter is for.  My stature is also a big factor in probably not ever getting a tank slapper.  I now also have a 900F swing arm which increases the length of the bike and should slow the turns.  Running a taller tire in the rear too, which should decrease the stem angle to the road and bring down the trail a bit more.  From sheer volume of these swaps done without altering the offset, I don't believe it will be much of an issue unless you're planning on running it on track days.
Will see how she does once I put it on the road.
I think cal is just making sure you are aware of the adverse effects of the swap.  I think his concern grew when the answer did not line up with an expected trail number.  Cal is looking out for us!  BTW sitting on the bike is going to adversely impact your trail, too :)
« Last Edit: January 30, 2018, 09:02:41 AM by MetroRedneck »
Offline work9to5
« Reply #15 on: January 30, 2018, 09:34:49 AM »
What?
