Author Topic: Temporary Ignition Switch override - suggestions wanted  (Read 1528 times)
Steelo
« on: January 04, 2007, 01:20:37 AM »
While I wait for another ignition switch electrical thingo - I want to basically connect the two corresponding wires with a switch to cut power when I stop.
What type of switch do I need ? 12 volt but how many amps?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: Temporary Ignition Switch override - suggestions wanted
« Reply #1 on: January 04, 2007, 01:41:58 AM »
When I got my bike the PO had a household light switch taped to the frame ::)
Offline 750goes
  • it will live
« Reply #2 on: January 04, 2007, 03:08:42 AM »
Go to Dick Smiths and get a simple toggle switch, tape it to the handle bars - but insulate your wires first - you only need the red and black from the ignition for on/off running....not sure about your lights though - does your right hand switch have a light switch incorporated with a DOT, P and L on it ??
PO on mine had three toggle switches mounted on the headlight shell - one for ignition on/off the other for lights on/off and hi/lo beam
« Reply #3 on: January 04, 2007, 04:07:51 AM »
If its only temp dont worry about rating as long as it is amps not milliamps---yes it will eventually burn out but by then you will have done a proper repair. If you want to be ultra safe same rating as fuse on the circuit
jdigga
« Reply #4 on: January 04, 2007, 06:27:41 AM »
I just did this last night because the one that was installed in the headlight by the PO burned out.
I bought one from Radio Shack rated at 25amps and some 1/4" quick connectors.  Red to one terminal and black, brown, and brown/white to the other terminal.
Works great until such time I can replace the proper ignition switch.
Offline 750goes
  • it will live
« Reply #5 on: January 04, 2007, 07:46:55 PM »
Steelo,
Have got a complete switch from a CB900 which has the 5 male points plus the plastic is good - do you want the whole switch -(sorry no key) as I don't want to try and remove the plastic from it -
I'll post up a picture tonight.....
