Author Topic: Cognito Rear Disc Conversion (CB550)  (Read 526 times)
Offline bambuhiphop
« on: February 05, 2018, 08:50:23 AM »
Hello All,
I am curious who has installed the disc conversion for the rear on a 550 from Cognito. I am specifically looking to understand the sprocket side and what stock components are needed. I get the brake side and the spacers but that sprocket side is eluding me.
Any one have pics or experience they can share?
Re: Cognito Rear Disc Conversion (CB550)
« Reply #1 on: February 05, 2018, 09:02:29 AM »
You will need all of the stock parts outward of the hub: dampers, flange, sprocket, etc.  https://www.partsfish.com/oemparts/a/hon/506b8b37f870023420a1e81c/rear-wheel
Offline bambuhiphop
« Reply #2 on: February 05, 2018, 09:04:03 AM »
This was my assumed list:
- Bearings (59 & 60)
- Axle collar (13)
- Axle collar B (14)
- Rubber ring (50)
- Dampeners (4 & 5)
- Final flange (12)
- Bear retainer (3)
- Collar (7)
- Sprocket (1 obviously)
- O-ring (51)
- Oil seal (48)
- Plate (2)
Numbers are based off this fiche: https://www.bikebandit.com/oem-parts/1975-honda-cb550k1/o/m9232#sch399584
« Last Edit: February 05, 2018, 09:05:36 AM by bambuhiphop »
