Author Topic: Re rack mikuni rs34  (Read 1472 times)
Offline T1m32sh1n3
Re rack mikuni rs34
« on: February 05, 2018, 03:58:56 AM »
Anybody know whats involved?
Offline turboguzzi
Re: Re rack mikuni rs34
« Reply #1 on: February 06, 2018, 07:46:27 AM »
racing carbs - so they should come stock with everything "slideable" to adjust for different carb spacings. see the slots in the spar?
« Reply #2 on: February 06, 2018, 08:25:13 AM »
One of the fuel tubes has to be shortened too. Be careful if you take them apart....there is a very small, spring loaded ball bearing used in the choke linkage...easy to lose
Offline T1m32sh1n3
« Reply #3 on: February 06, 2018, 10:17:59 AM »
Thanks for the info.
« Reply #4 on: February 06, 2018, 06:50:48 PM »
I should add you basically push the carb bodies as close together as they can go.
Offline T1m32sh1n3
« Reply #5 on: February 07, 2018, 04:13:30 AM »
Thanks turboguzzi and mrieck
« Reply #6 on: February 12, 2018, 08:24:40 PM »
 I've seen some used ones (Suzuki?) with the fuel tee in the center. That won't work well either.
