Author Topic: CB500 Pistons and Rings Opinions  (Read 939 times)
Offline rtbmrgl
  • Got Points! Roseville, Ca
« on: February 07, 2018, 07:31:05 AM »
CB500 Pistons and Rings, I need a set, first over will do it.
 I see a lot available, Opinions on brand, oil ring type, etc.
Not interested in high comp, unless you think I can run with pump gas.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Online jaytee-nz
Re: CB500 Pistons and Rings Opinions
« Reply #1 on: February 07, 2018, 03:58:47 PM »
I would stick with what Mr Honda supplies - genuine parts are always best in the vast majority of cases.
Offline rtbmrgl
« Reply #2 on: February 08, 2018, 10:07:22 AM »
I found a set of ART pistons, which is what Honda used.
thanks, Mark
Roseville, Ca
Got Points!
« Reply #3 on: February 08, 2018, 01:37:05 PM »
you can use xl125 pistons but they will give pretty high compression!
Offline rtbmrgl
« Reply #4 on: February 10, 2018, 08:30:10 PM »
Thanks Dave, I just re-started and old thread, Jetting spreadsheet project.
I saw your jetting setup, which included your pistons. Does it run ok on pump gas, Im in Calif
 http://forums.sohc4.net/index.php/topic,78305.msg873577.html#msg873577
thanks, Mark
Roseville, Ca
Got Points!
« Reply #5 on: February 10, 2018, 09:34:33 PM »
i had the combustion chambers relieved a little,ran ok on our 98 non ethanol
Offline rtbmrgl
« Reply #6 on: February 11, 2018, 09:23:30 PM »
I think I'll stick to stock pistons, Calif gas is not the best. Highest octane near me is 91, I'd have to go the airport to get higher.
thanks though.
I found a set of ART pistons, not oem Honda.
Whats the opinion on oil ring, three or one piece.
thanks, Mark
Roseville, Ca
Got Points!
« Reply #7 on: February 11, 2018, 11:28:28 PM »
three piece!!
