Author Topic: Wiring Help - Idiot Lights  (Read 977 times)
Offline JonathanHValencia
« on: February 23, 2018, 04:29:28 PM »
Hey folks,
The original idiot lights have one wire to each light. For example, the right turn signal has one wire, baby blue
My new lights from Cognito Moto are imbedded in my top triple clamp and have a black and colored wire for each light. I can’t figure out how to wire these. Can someone help?
I asked them and they said “Should go just like stock. Each wires positive is colors the same as the LED. You will need to touch each to a battery to find the ground on each matching LED. The oil and neutral are the only ones that are reversed. Meaning that the colored wire is wired to an auxiliary positive and the black wire goes to the switches that are ground.“
Can somebody clarify. I’m new to this
Offline rotortiller
Re: Wiring Help - Idiot Lights
« Reply #1 on: February 24, 2018, 08:04:27 AM »
Neutral and oil are ground seeking switches the rest are positive.
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #2 on: February 24, 2018, 08:09:28 AM »
LED's are actually a diode that passed voltage only one way. So you hook up the two wires to 12v and ground, and the way that they light up is the correct way to wire them into you harness. Now the neutral and oil lights, go to the switch with the negative side that you determined go to ground. The other side goes to 12v. It isn't that hard to figure out, and if it doesn't work one way, swap the wires around. You will figure it out.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline rotortiller
« Reply #3 on: February 24, 2018, 08:26:54 AM »
Depending on the bike and LEDs you may have signal light cross feed and have to deal with that using diodes. Here's one I did a while back.
« Reply #4 on: February 24, 2018, 09:17:50 AM »
So for high beam, and turn signals it’s color to power and black to ground? And vice versa for the neutral and oil?
Offline Yamahawk
« Reply #5 on: February 24, 2018, 09:21:22 AM »
I believe so. The only one that may need the diodes as mentioned is the turn signal indicator, as there is only one.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
« Reply #6 on: February 24, 2018, 10:02:11 AM »
Hmmm,
Even tho there’s a desperate switch for each? A blue and orange?
« Reply #7 on: February 24, 2018, 10:02:36 AM »
How did you wire it using diodes?
Offline Bodi
« Reply #8 on: February 24, 2018, 10:36:45 AM »
If there are separate directional idiot lights you don't need any diodes.
Yes the neutral and oil lights get all-the-time + power from any handy black wire as the switches connect their lights' wires go to ground. Wiring for accessory lights can use green or black for ground and any non-green color for "+" power. Unless whoever makes them is mental, green is always "-" and red is always "+".
For connecting a bike's single indicator to a LED lamp it's just two diodes, one from each signal wire to the LED "+" wire (both connect to the one LED wire) and the LED's "-" wire to ground. Without the diodes, the LED will light for one side only.
Offline rotortiller
« Reply #9 on: February 24, 2018, 11:00:09 AM »
The two diodes are shown in the diagram.Since you have 12V LEDs you do not need the resistor.
« Reply #10 on: February 24, 2018, 12:27:27 PM »
I have two yellow signal idiot lights. One on each side of neutral.
« Reply #11 on: February 24, 2018, 12:28:57 PM »
My level of proficiency in this is negative 3. That diagram is Chinese to me lol
Offline rotortiller
« Reply #12 on: February 24, 2018, 01:14:24 PM »
Diodes as mentioned are not needed then. You likely have a later model SOHC. I'm running LED indicators in my K7 fine but using the OEM sockets.
« Reply #13 on: February 24, 2018, 02:38:16 PM »
My idiot lights are from Cognito Moto. They’re aftermarket and imbedded in my top triple.
