Author Topic: #3 carb not quite right  (Read 1542 times)
Offline KeithB
« on: February 24, 2018, 07:02:23 AM »
1974 CB750K
All main and pilot jets are new.
Carbs have been cleaned
Accurate vacuume carb balance done and "air screws" set the same.
All float levels checked and the same and needles at the same clip setting.
All plugs new and coils good and wires and caps clean an correct.
Timing is strobe accurate.
When I start the bike, it needs choke for a short time and then will idle with no choke.
#1-2-4 cyl seem to be running right and the exhaust pipes heat up more or less the same.
 #3 is a bit reluctant and pipe doesn't heat up the same.
If I take 2 fingers and put them over the intake to the carb and get it to pull a bit more fuel, #3 runs well  for a short time.
Not sure what the cause is but it seems to be lean at idle.
Thoughts?
Nanahan Man
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
Re: #3 carb not quite right
« Reply #1 on: February 24, 2018, 07:22:06 AM »
Hi Keith,
  What you describe is a lean condition on the #3 carburetor. Whether it is from jets, passages, or an air leak is the conundrum...
If you are sure that you carb passages are clean, (internally) then I would search for an air leak at the manifold using starting fluid or carb cleaner, spray it at each connection and see if there is a rise in rpm. I am sure you will figure it out. If it isn't air or fuel, the next thing is the coils and wires, for that #3 cylinder. There is always a chance that the wire isn't making good contact, or is arcing out on the frame.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline KeithB
« Reply #2 on: February 24, 2018, 07:59:43 AM »
I'm 100% sure it's not wiring as I am very comfortable with electrics and I have done a very comprehensive diagnostic.
The air leak is something I will double check.
there is always a chance that a bit of something didn't come out of a passage with the cleaning. ::)
Nanahan Man
Offline Yamahawk
« Reply #3 on: February 24, 2018, 08:06:00 AM »
Yep, did you actually install new plug wires? They do break down over time, and can arc out. If you can, at night or in a dark garage look at the wires with the engine running to see if there are any sparks to ground.
There is always that chance there might be a speck of dirt somewhere in that circuit, or in the pilot jet too. I have seen my own pilots get narrowed through sediment that is very hard to clean out, and gives a tiny peep hole that isn't as large as when it was new.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline KeithB
« Reply #4 on: February 24, 2018, 09:12:51 AM »
Charlie
While I take your point, trust me when I say I have covered the electrical part of this problem.
I suspect you are on point with potential debris remaining in the low cct passage.
Nanahan Man
« Reply #5 on: February 24, 2018, 02:28:57 PM »
A slightly-lower float level in the #3 bowl will cause this, too. You can test this a bit by turning the #3 screw outward about 1/4 turn to see if it gets better: if it does, then the bowl is running slightly lower than the others. This can happen from the infamous "dimples" that appear after a while on the float tangs, where they push the float valve shut: it makes a slight latch that tends to prevent the float valve opening as the levels starts dropping, and also tends to make it overflow momentarily (and intermittently) if new float valves were installed, but the dimple was not removed.
Offline KeithB
« Reply #6 on: February 26, 2018, 08:42:53 AM »
I was suspecting something like a lower level and could not think of an easy way to test.
thanks.
Nanahan Man
Offline Sellsme
« Reply #7 on: February 26, 2018, 01:20:20 PM »
I had sort of the same thing, number 4 for me. after disassembling  many times no luck. THEN I found it. one of the needle jets was a smaller size than the rest. The needles themselves were marked and correct but the jets were not marked. I  had no way of knowing what size the jets were. Until I removed every little part and slid the needle jet over the needle. #4 jet would not slide all the way down the needle but the other 3 would would. Take nothing for granted, over 40 years of others messing with these carbs.
Don't try to make sense out of what don't make sense....
Offline KeithB
« Reply #8 on: February 27, 2018, 05:02:27 AM »
I did check the jets and they are marked the same but next time I have them off the bike I will take a close look at the needle to jet fit.
Thanks for the tip :)
Nanahan Man
Offline KeithB
« Reply #9 on: March 02, 2018, 04:15:25 AM »
Tried adjusting the screw but it made no difference. All the boots are very tight but I will do a leak test. Propane from a torch should work.
I am going to try raising the float level a mm to see if that works.
Another thought I had was allowing a little more vacuum on #3 when doing a balance with vacuum gauges.
Otherwise, the carbs come off (again!) for a complete inspection.
« Last Edit: March 02, 2018, 04:53:12 AM by KeithB »
Nanahan Man
Offline DV Red Herring
  • Army RETIRED
« Reply #10 on: March 02, 2018, 05:08:47 PM »
I'm just going to throw this out there. I had a similar situation happen, and after chasing all the rabbits down the hole... come to find out I had a faulty spark plug. Even brand new NGKs can be bad out of the box.
« Reply #11 on: March 02, 2018, 07:35:13 PM »
More than one! Especially if the parts dealer dropped them once (or more)... :(
Offline KeithB
« Reply #12 on: March 03, 2018, 04:49:53 AM »
As noted in a previous post, I have carefully exhausted the possibility of bad plugs, caps, wires and coils.
But let's explore this.
How would  choking a carb and making the mixture rich would "solve" a bad plug problem?
Nanahan Man
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #13 on: March 03, 2018, 06:54:52 AM »
my votes are leak at boot between carb and motor or low/stuck float.
cb750 k6 - ugly
Offline KeithB
« Reply #14 on: March 04, 2018, 03:21:43 AM »
I did pull the carb bowls a number of times to check the floats and the fuel level.
The leak is something I will check out this coming week.
Nanahan Man
Offline KeithB
« Reply #15 on: March 15, 2018, 05:29:21 AM »
Update...
Checked for leaks in carb boots. All tight.
Raised the float level just a touch. No difference.
Changed "air screw" position. No difference.
It does backfire a bit and spits fuel back out of the carb intake  when rolling on the throttle.
#3 pipe never seems to get as hot as the other 3.
Can't really do a plug chop as it's still not good weather to get out on the road.
Maybe re-check the valve lash?
Other than this one problem, the bike starts and runs fine.
Nanahan Man
Offline evinrude7
  • not a kung-fu
« Reply #16 on: March 15, 2018, 06:54:17 AM »
Update...
i had a problem once where a float was bent.  the two sides of it were splayed outward from one another and it was rubbing on the bowl sides, getting stuck.  not sure what carbs you have.  maybe this can't even happen with your floats.
cb750 k6 - ugly
Offline KeithB
« Reply #17 on: March 15, 2018, 09:03:31 AM »
Update...
Good idea.
Already checked that floats are working correctly.
I'm out of ideas.
Nanahan Man
Offline evinrude7
  • not a kung-fu
« Reply #18 on: March 15, 2018, 05:00:02 PM »
sorry keith.  hope you get it sorted soon.
cb750 k6 - ugly
Offline KeithB
« Reply #19 on: March 17, 2018, 07:16:41 AM »
One of these things is not like the other (3) so if I keep at it, I'll figure it out. :)
Nanahan Man
