Author Topic: What the heck happened to my petcock!?  (Read 4587 times)
Re: What the heck happened to my petcock!?
« Reply #25 on: February 24, 2018, 05:26:08 PM »
to force a bigger screw will require the face plate to be drilled to clear that bigger screw.
Offline Flyin900
« Reply #26 on: February 24, 2018, 06:01:58 PM »
Dos it needs to be done right and tapped with a correct size tap.
A tool supply place should have the correct sized metric tap and Harbour Freight should have a really inexpensive metric small metric tap and die set for $20-25. It is something good to have in your tool crib as it will come in handy for other metric nut/bolt repairs.
I think those existing holes in the petcock were M4 X .75 TP screws, so an M5 X .8 TP  will retap the stripped threads and I just checked against a CB400F petcock and there is enough meat left to tap that size hole in the petcock body.
The metal plate as Dave500 mentioned will need to be drilled a little larger to accept the 5mm screw, yet only tap the petcock body by hand and you should be able to tap with no drilling as the metal is very soft in that body.
Another point if you do retap is don't over tighten the new screws on the metal plate, since you don't' need anything beyond just snug, as the spring washer you reversed inside is what applies the pressure on the seal in the petcock.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
« Reply #27 on: February 24, 2018, 06:54:28 PM »
the metal is a zinc alloy,pretty crumbly take care,just get a new fuel tap,with all due respect I think the work involved to repair it may be out of your experience/skill scope and if its no good you just spent money on stuff youll hardly use?,new ones are obtainable even repros,if it was some rare oddball thing from the 1940s and not obtainable new that's where youd go the extra mile and repair the old one.
Offline Dos
  • Owner of a cb350f
« Reply #28 on: February 24, 2018, 10:49:46 PM »
Thank you all for the advice I appreciate it, I’m going to post around and see if I can buy a used one that works. If I can’t ill retap. I’m sure most auto shops would have one?
« Reply #29 on: February 24, 2018, 10:58:47 PM »
auto shops will have imperial,just so you know,#$%* just buy a #$%*ing new one,itll last forever.
Offline Dos
  • Owner of a cb350f
« Reply #30 on: February 24, 2018, 10:59:59 PM »
Is the cb400f petcock identical? If so I’ll buy that  ;D
« Reply #31 on: February 24, 2018, 11:00:44 PM »
let me google that for you?
Offline Dos
  • Owner of a cb350f
« Reply #32 on: February 24, 2018, 11:03:14 PM »
Unfortunetly it’s not
Offline Dos
  • Owner of a cb350f
« Reply #33 on: February 24, 2018, 11:05:55 PM »
Please direct me where a new Cb350f petcock is available
« Reply #34 on: February 24, 2018, 11:08:01 PM »
im going directly to the fridge to get a beer.
« Reply #35 on: February 24, 2018, 11:15:28 PM »
BURRRP! ok got a beer,this is the best I can do.
http://lmgtfy.com/?q=honda+350+four+fuel+tap+single+outlet
« Reply #36 on: February 25, 2018, 12:29:22 AM »
That's brilliant Dave, can you do another search for me? I'm looking for "Slutty girls with big boobies"............ ;D
« Reply #37 on: February 25, 2018, 12:41:39 AM »
I wont google that for you terry,ill just send a couple of sluts around to your place!(I don't wanna contaminate my computer!)
« Reply #38 on: February 25, 2018, 12:46:07 AM »
whats your address again terry?ill just send it to some Russian sluts I know online,oh the fuel tap,yeah well Dos i guess you got it figured by now?
« Reply #39 on: February 25, 2018, 12:57:48 AM »
best I can do terry,i tried hard.
http://lmgtfy.com/?q=terry+from+australia+sohc+forum+is+a+#$%*
I checked the results out no flaps?
« Reply #40 on: February 25, 2018, 02:17:45 AM »
That was pretty disappointing Dave, but thanks anyway........... ;D
« Reply #41 on: February 25, 2018, 02:52:54 AM »
Any shop will lkely charge you half of a new one to tap it.
 Measure your 2 bolt or 2 screw pattern  that holds it to the tank, then compare it to a 750 or 500 one. Or a 350 twin or 450.. Then if it's same get one of them,  plug off one outlet.. that will take 1 1/4 inch of hose and a small bolt and maybe a clamp or McGyverWire.
« Last Edit: February 25, 2018, 07:50:03 AM by 754 »
Offline WhyNot2
  • I'm finally an
« Reply #43 on: February 25, 2018, 06:18:13 AM »
~~~~~~{iii}?~~~~~~~~~prost
Offline Flyin900
« Reply #44 on: February 25, 2018, 12:40:39 PM »
According to my Honda parts cross reference fiche the only model the #16957-333-025 petcock was used on was the 1972-1974 CB350F.
So try finding a used petcock body and transfer your new parts into it, or retap.
Offline Flyin900
« Reply #45 on: February 25, 2018, 01:00:06 PM »
So 4 into 1 a parts supplier out of San Fran has a CB550 aftermarket petcock that has dual fuel outlets that they say can be used on a CB350F, so the mounting pattern to the tank must be the same. They suggest using a dual line with a combiner into one line and do indicate it will work, yet the fuel line routing is more difficult than stock. The other option is the block off the second outlet if routing it is easier. The good news is the cost is $22 US for a new unit.
Offline Dos
  • Owner of a cb350f
« Reply #46 on: February 25, 2018, 01:03:19 PM »
Yes I saw that however someone responded for my “looking for “ thread and I’m buying one from Bill. Thank god.
« Reply #47 on: February 25, 2018, 01:15:38 PM »
no!thank Bill!
Offline Dos
  • Owner of a cb350f
« Reply #48 on: February 25, 2018, 01:26:21 PM »
Haha I did
Offline Dos
  • Owner of a cb350f
« Reply #49 on: February 25, 2018, 01:26:55 PM »
Waiting for him to post pic or reply
