Author Topic: What did you do to your non-motorcycle vehicle today?  (Read 312335 times)
Re: What did you do to your non-motorcycle vehicle today?
« Reply #4150 on: May 25, 2025, 04:27:26 PM »
im in a similar situation , thinking of retiring next year but have no room at home for all the vehicles stored at work .
cant quite face selling any of them so it looks like i am looking for a house in the country with a large barn !
Don't forget that no matter how big the shop is you will manage to fill it up fairly quick. 8)
Yeah I’ve thought about that too Simon, I could sell my house in the burbs and buy a new house on a couple of acres in the country, but I know that if I had a bigger shop I’d just keep filling it with bikes and cars. I rode my K100RS SE over to the auction place yesterday and looked at the log book, and I haven’t ridden it at all this year, like most of my bikes, so it’s better going to someone who will use it more often.
I’m hoping that the 10 year old Motobatt battery that I pulled out of the Triumph Rocket III and put on my battery charger will have enough life left to fire it up today so I can ride it to the car wash and give it a much needed clean before I take it over to the auction place. If it needs a new battery I’ll buy one and install it, because no one in their right mind would buy a R3 without hearing it running first, and it’ll make it easier to sell. I was even going to take my faithful old Sporty across before I remembered that my youngest boy wants to eventually swap his Royal Enfield for it, so that’s a good thing, the Sporty is a lovely old thing. ;D
You would regret selling the Sporty. You're so happy every time you ride it  8)
Thanks Kelly, and you are right, it’s a lovely old bike. Good news is that I remembered that my youngest boy was keen to have it a few years ago so I asked him if he still wanted it and he said yes, so it’s going to a good home. No money will change hands, the deal is he’ll swap his 2019 Royal Enfield 650 that he bought new, for the Sporty.
The good thing is that we’ll be able to ride both bikes whenever we want. I’m taking the Triumph Rocket III across to the auction place today, I charged the 10 year old Motobatt battery up last week and went for a ride yesterday with no issues, so I’ll ride it to the car wash and give it a good clean, then over to the auction place. I have mixed feelings about selling it, but it does take up a lot of space, and the VMax will be just as exciting to ride. ;D
Offline BenelliSEI
  • 1969 cb750
« Reply #4151 on: May 25, 2025, 05:33:57 PM »
Noticed a small oil leak leak under the race car (drip, drip can be a few cups over an eight hour race).Pulled off the front plastic to have a good look. The 180 degree AN-10 fitting at one end of the oil cooler as dripping under pressure. Tightened it up and no joy. Looks like the seal in the “swivel” head is leaking. I don’t think that can be a fixed, ordered a new one. Good thing I went to have a look. Another fitting, further along, is slowly notching into the water rad and needs to be relocated!
Lots of small stuff to do, but no pressure. Next race isn’t for several weeks. Double header at Mosport will be a highlight!
« Last Edit: May 25, 2025, 05:38:21 PM by BenelliSEI »
Offline grcamna2
« Reply #4152 on: May 25, 2025, 08:02:09 PM »
I like the front splash pan/spoiler and the bumper removes to allow access to let you work on it.  8)
75' CB400F/'bunch o' parts'
Offline BenelliSEI
  • 1969 cb750
« Reply #4153 on: May 26, 2025, 06:17:52 AM »
Set up with pins and clips. Two bolts and it’s off in 20 seconds. Both front fenders can be off in a 2-3 minutes too.
Offline grcamna2
« Reply #4154 on: May 26, 2025, 08:42:39 AM »
Excellent.
Do you still have spare front(fenders,hood,lower splash)body panels ?
Offline CycleRanger
  • No comment about being an
« Reply #4155 on: May 26, 2025, 11:38:56 AM »
Changed the oil in my '02 Tundra yesterday. Yay me!  ;D
Offline BenelliSEI
  • 1969 cb750
« Reply #4156 on: May 27, 2025, 06:09:23 PM »
Quote from: grcamna2 link=topic=170989.msg2318243#msg2318243 Ldate=1748228529
Excellent.
We actually picked up two spare cars! One is a “sport wagon” and the other is the blue sedan I pinched the left front fender, bumper and front cross member from last year after my “off” in the rain at Mosport.
Both cars run well, but suffer from an unbelievable amount of rocker panel rot (paid less than $500 for each of them). Last time I pinched a LF upright off the sedan, I jacked it up with a floor Jack, under the original jacking point. While I was pressing it apart in the shop, I heard a loud crash outside. The Jack went right through to the door and the car was on the ground!!!!
Had to use the tractor bucket to lift it off and put it back in its resting place. Fortunately our race car was built from a new shell and has never seen snow or salt!
« Last Edit: May 27, 2025, 06:48:16 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #4157 on: May 27, 2025, 06:15:54 PM »
Today I moved the cooler box for the “cool shirt” into the RR passenger seat well, so I can move the battery from under the hood to the RR passenger footwell. Despite our best efforts the RR is always a bit light when we set the corner weights. These weight shifts should square it up nicely!
Offline BenelliSEI
  • 1969 cb750
« Reply #4158 on: May 27, 2025, 06:24:51 PM »
Not sure if I posted this yet….. Used our corner weights scales to check over my buddy Al’s “Nostalgic Drag Racer”. He built this from scratch. Glass body on his own frame. Real early ‘60’s HEMI on alcohol and a blower. If you look closely you can see the full scale drawing on the back wall to ensure all his suspension pick up points align just the way he needs to drive the rear axle into the ground on “blast off”. The fit and finish on this one are extraordinary. Took him 18 months o build.
Al has been drag racing for over 55 years  (he’s 74) and is usually the class of the field. Engines, fabrication, bodywork and paint are all done by him, on his own, in his own shop. He is a class act! Car was about +12 lbs. on the LF and otherwise perfectly balanced. It goes out next weekend, after he pulls the paper off the Lexan windows! When I grow up, I want to be just like him.
« Last Edit: May 27, 2025, 06:30:27 PM by BenelliSEI »
Offline grcamna2
« Reply #4159 on: May 27, 2025, 06:43:43 PM »
Nice Hot Rod there.  8)
« Reply #4160 on: May 28, 2025, 01:46:04 AM »
tell him excellent!!
Offline BenelliSEI
  • 1969 cb750
« Reply #4161 on: May 28, 2025, 04:51:34 AM »
Will do Dave! I should take a few more pictures. The rads are under the frame, passenger side, with two small fans. The motor cools itself with the alcohol blasting through it, but Al is usually on his own and drives it back to the pits. Electric water pumps “ON” and he does! The car is filled with cool little details!
« Reply #4162 on: May 29, 2025, 01:47:46 AM »
 It looks Like the Malco gasser, one of my favorite cars. I still buy Malco tools when I can. They make a lot of sheet metal tools and a cool oil filter wrench.
Offline BenelliSEI
  • 1969 cb750
« Reply #4163 on: May 29, 2025, 05:34:45 AM »
Don….. The f’glass body was made by a local shop in the ‘70’s. Never fitted and lay around for decades. It was pretty crude and warped. Al picked it up for a few hundred dollars and then spent months getting it straight and smooth. It looks great now……
Offline grcamna2
« Reply #4164 on: May 29, 2025, 08:42:31 AM »
That must have been a Lot of hours of labor to get it looking so very nice;quite a project.  8)
Offline BenelliSEI
  • 1969 cb750
« Reply #4165 on: May 29, 2025, 12:10:18 PM »
Relocated the Cool Shirt box further back and moved the battery from under the hood, low down in the rear footwell of the LEXUS. +1 month to our next race weekend, but a long list of “things to do”…..
« Last Edit: May 29, 2025, 07:19:18 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #4166 on: May 29, 2025, 07:21:12 PM »
He’s a perfectionist in everything he does!
Offline grcamna2
« Reply #4167 on: May 29, 2025, 08:31:44 PM »
« Reply #4168 on: May 30, 2025, 07:05:47 AM »
Relocated the Cool Shirt box further back..
Hey John...not all the guys may know what a "Cool Shirt" is: the box pumps cool water through a special shirt to keep the driver cool in hot weather. [most race cars always have a hot interior].
I've also seen "cool boxes" filled with ice and an air pump to cool the driver.
Offline simon#42
  • liverpool
« Reply #4169 on: May 30, 2025, 09:35:12 AM »
thanks for that steve i did wonder !
Offline denward17
« Reply #4170 on: May 30, 2025, 12:47:26 PM »
Been a hoot the last couple of weeks with my '05 Tacoma. Two Sundays ago was getting ready to go to the coast for a week, truck loaded down with all supplies.  The week before decided to have the u-joints and center bearing replaced, center bearing was worn out and you could move the driveshaft about 1" or more up and down.  Took it to a local driveline shop. I purchased the truck new, now has about 126k miles.
Heading to the coast, on the road 30 min, brake light comes on, stop to check fluid, was low of course.  Thought that was odd, when I stopped to get fluid, I looked at all 4 wheels to see if anything was wet, nothing was, so I drove on to the coast.  Out on a major highway going about 60-75mph noticed a new humming sound and felt a vibration, dang driveshaft I thought.
Just as I was pulling into the rented condo, the light came on again (about 3 hour drive).  After driving around the coast a bit, ended up putting 2 1/2 8oz cans of brake fluid in, but it got me home.  Brakes still worked pretty good.
Troubleshooting found an internal leak to the master, and yep, all that fluid I put in was going inside the booster, almost to the point of leaking out.  Off to parts store to order stuff.  The next day parts came in, of course the wrong master was in the correct box (O'Reillys).  Kept the booster and went to NAPA to get a master, had to wait another day.  Got the master and had trouble bleeding.  The only thing I could figure out was probably had air in the ABS unit.  Still had a mushy pedal.
So knew I had to activate the ABS, so was thinking of going to the Toyota dealer to get it bleed (they have some type of scan tool).  Then read on the Tacoma world forum where you could drive on a dirt road and hit the brakes hard multiple times to active the ABS.  I did this and re-bleed the system.
Finally good brakes again................
Now for the driveshaft, took it back to the driveshaft shop and had it balanced, now vibration/noise free......whew! what a week.
« Last Edit: May 30, 2025, 12:49:03 PM by denward17 »
« Reply #4171 on: May 30, 2025, 02:23:50 PM »
Dont lie!its got beer in it,and what a mission on the tacoma!!
Offline BenelliSEI
  • 1969 cb750
« Reply #4172 on: May 30, 2025, 05:36:38 PM »
Steve….. good point! The shirt actually has very small tubing sewn all around the chest and back. The pump control switch (on the dash) allows the driver to turn it on and off and vary the flow rate. The guys put about 6” of water in the cooler and then stand up a few large Tupperware containers (filled with frozen water) inside. They swap in fresh ice every two hour pit stop.
The other guys are 10 and 20 years younger than me and I drive them nuts. I hate the thing and never use it. Funny about the beer. We usually float a Cola in there so if the car breaks down (or crashes) the poor driver has a cold one……
« Last Edit: May 30, 2025, 05:40:52 PM by BenelliSEI »
« Reply #4173 on: May 30, 2025, 06:48:07 PM »
my driver seat belt has been worn out for years,Ive cut n burned the fraying once or twice and its a pain to use now it gets snagged a bit,so I decided to buy a new one,only 125 bucks and made in Australia!!
« Last Edit: May 30, 2025, 06:53:04 PM by dave500 »
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #4174 on: June 01, 2025, 10:09:06 AM »
Just a boring oil change in my dirt driveway.
Bud
1973 CB750K3 Chopper (in pieces)
