Author Topic: What did you do to your non-motorcycle vehicle today?  (Read 376666 times)
Re: What did you do to your non-motorcycle vehicle today?
« Reply #4575 on: January 02, 2026, 01:37:45 AM »
A few years ago I "inherited" my son's twin turbo Subaru, and love it, but my creaky old knees struggle with the heavy duty clutch, especially in traffic. A few weeks ago I found another, low mileage automatic beasty going ridiculously cheap on FB MP because it had a blown turbo, so as I had a spare turbo in my garage, I lowballed the seller some more, we agreed on a price a fair bit less than he wanted, and I had it towed back to my place.
I spent the next week or so removing/installing the old/new turbo's, and cursing Subaru for stuffing 50 pounds of crap into a 5 pound bag. The amount of things that I had to remove just to get to the turbo to remove it, then all the other things I had to remove to get the good turbo in was mind boggling. What was hilarious was that Nelson, the Chinese guy I bought it from, had driven the car for several miles with the blown turbo, so the intercooler and exhaust was full of oil. I dumped the intercooler in a big tub of water based degreaser and used a submersible pump to flush it out, over several days, then flushed it with water.
I dropped the front section of the exhaust off to wrestle the good turbo into place, and oil just poured out onto my concrete driveway. Fcuk. Anyway, I managed to install the good turbo, then installed a new battery, did an oil and filter change, replaced the air filter, fuel filter (in tank, what a PITA) drilled the thermostat, replaced the coolant, and summoned up the courage to attempt to start it. Surprisingly, it started right up, which made me happy, because I had no idea of the engine condition until then.
The problem of an exhaust system full of oil manifested immediately. Within seconds of starting it, the smoke blocked out the sun. Fcuk. I switched it off, and prayed for a strong wind, to disperse the smoke. One of my greatest fears materialised when the siren from the fire station less than a mile from my place sounded, and I could hear a fire truck coming my way. In hindsight, creating heaps of smoke on a 37 degree C (close enough to 100 degrees F) day probably wasn't that smart, but luckily for me, by the time the fire truck slowly cruised past my place, the smoke had cleared, and I didn't get in the sh1t.
I did wonder how I was going to sort the problem, and probably around 3am, I had an epiphany. Next morning I drove over to the hardware store and bought a big dust extractor, and ran the pipe thru a big tub full of water, which seemed to work quite well.
Once I'd run it for about an hour, and "burped" the cooling system I took it for a drive around the block, but the smoke hadn't completely gone away, so the next morning I woke up very early before most cars were out on the road and drove it 120 miles. I really didn't need to drive it 120 miles, the smoke had cleared after the first 10 miles or so, but it was just so much fun to drive, this thing has around 300 BHP @ 14 psi, in a compact little car. I still need to jump through some legal hoops to get it back on the road, but hopefully it'll be registered and running around town in a couple of weeks. ;D
« Reply #4576 on: January 02, 2026, 08:01:41 AM »
Terry, did the oil foul the oxygen sensors and catastrophic converter?
Offline BenelliSEI
  • 1969 cb750
« Reply #4577 on: January 02, 2026, 08:03:36 AM »
Terry…… easily “Best Post of the Year” so far! Laughed all the way through (twice).
A few weeks ago I replaced a rad hose in the Volvo C30 and had the same experience: removed the battery and battery box, ECU, air box, intercooler pipes, lifted one end of the engine off the mounts, and a ton of other #$%*e before I could even spot the hose!!
I bet that exhaust system never rots. Kudos to you!
Offline grcamna2
« Reply #4578 on: January 02, 2026, 08:56:44 AM »
I can only begin to imagine the lengthy hours you've spent working on your newly acquired Subaru twin turbo car. Terry,do you like how the automatic transmission shifts and does the car handle well with a good interior? Glad to hear your post on another successful auto repair you've accomplished  ;) Good New Year 2026' to you Terry.
« Last Edit: January 02, 2026, 08:59:27 AM by grcamna2 »
75' CB400F/'bunch o' parts'
« Reply #4579 on: January 02, 2026, 12:34:01 PM »
worlds largest bong?
« Reply #4580 on: January 02, 2026, 12:57:35 PM »
Thanks guys, there were a few other things I had to do to get it done, but it would read like a book titled “Why you should never buy a Subaru with a blown turbo”. It goes great now, sadly I have to take it to the exhaust shop and get a more restrictive rear muffler installed as it won’t pass the Roadworthy Inspection with the one that’s on it now, but I’ll keep the old one for after the car’s legally registered, and put it back on.
Bill, it goes like a rocket, it’s been chipped to release all of the ponies and I have to be very careful with my right foot. It’ll kill my manual B4 in a straight line, but won’t be as much fun in the twisties as a manual, with no engine braking. No matter, it’s also got cruise control, so will be more enjoyable on a long drive. ;D
Offline grcamna2
« Reply #4581 on: January 02, 2026, 01:15:47 PM »
I lightweight screamer/hotrod !  ;D
« Reply #4582 on: January 03, 2026, 12:50:23 PM »
I drove the Subaru around to the exhaust shop and Tony put it up on the lift, and said that there was nothing wrong with the 3 inch “Cat-back” exhaust, so I rang Naidar, the Roadworthy Inspector and handed the phone over to Tony. After a 5 minute argument Tony agreed that for the purpose of a Roadworthy pass he’d need to quiet it down a tad, so removed the big exhaust and installed a cheap aftermarket system, but will reinstall the sports system once I get it registered. It still goes fine with the restrictive exhaust, but I can feel the difference. Oh well, it will go back on soon, and sound as good as it goes.
Offline BenelliSEI
  • 1969 cb750
« Reply #4583 on: January 04, 2026, 02:36:30 PM »
Nice set!
« Reply #4584 on: January 05, 2026, 07:13:48 AM »
Nice set!
+3!
Twin cars with turbos ;D
Probably 4WD too.
Offline denward17
« Reply #4585 on: January 05, 2026, 03:12:42 PM »
Spent a little time with the '05 Tacoma (130K miles) today.
Changed oil, oil filter, air filter and spark plugs.
Plugs on the driver side are a pain to get to, but not too bad, took about 2.5 hours, slowing down a little in my older age.
« Reply #4586 on: January 05, 2026, 09:18:29 PM »
 I re-did some of the stainless exhaust on my firebird and ordered a brand-new body.
  It will have a flat firewall and the front floor will be tech screwed in so I can remove it, drop the new body onto my Art Morrison chassis and already mated floor pan. It will be around 90% brand new 69 Bird. The issue is, I get 6 months to get ready for it to arrive, it's good to have a deadline.
Offline grcamna2
« Reply #4587 on: January 05, 2026, 09:25:16 PM »
Yeah !!  :)
Offline BenelliSEI
  • 1969 cb750
« Reply #4588 on: January 06, 2026, 07:12:22 AM »
Wow….. looking forward to seeing this one!
« Reply #4589 on: January 06, 2026, 01:00:11 PM »
+1 !
Offline BenelliSEI
  • 1969 cb750
« Reply #4590 on: January 06, 2026, 04:29:08 PM »
I’ve mentioned this in the past. The three mechanics (all fully qualified) that work in Tim’s Shop (the guy I race the Lexus with), all have dirt bikes and snow machines. Despite their trade, they usually bring me the small carbs for rebuilding. Truth be told, they never work on anything with carbs!
They always come by when it’s time to hoist a motor, or I need a hand with anything around the farm, so I never say no. One of them bought a pair of older Yamaha snow machines over the weekend. The plan is to build “one good one”. A pair of Mikuni 80L carbs showed up on my door step this morning! Very rough, full of crap and seized throttle shaft. One down, one to go. I actually enjoy this, as they always bring something I never seen before! Here’s the “BEFORE” photo.
« Last Edit: January 06, 2026, 04:33:45 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #4591 on: January 06, 2026, 04:41:50 PM »
These Mikunis have a small micro switch that closes whenever the throttle pad is back to “idle”. The rubber boot had rotted away and the wires were pulled out of the plastic switch. Nor replacements available……
Stripped back the wires and managed to get them back in the broken clips (micro stuff, buried in plastic). Using lots of flux paste, I was able to heat the bare wire and get a blob of solder to run down and reconnect them both! Mixed up some two part JB Weld putty and molded a permanent “boot” to stop any vibration and strain on my connections.
No idea what it does on the machine, but it’s going to work again.
Offline BenelliSEI
  • 1969 cb750
« Reply #4592 on: January 07, 2026, 11:51:17 AM »
Finished up. Look scruffy, but spotless inside. Bench sync’d and they’ll work.
Offline grcamna2
« Reply #4593 on: January 07, 2026, 01:00:48 PM »
It's how the inside looks that's Best  ;) :)
Offline BenelliSEI
  • 1969 cb750
« Reply #4594 on: January 07, 2026, 01:57:59 PM »
The machine was left inside, so they were not too bad internally. They are stamped Mikuni 80L and oddly I could find no info or parts for them. Yamaha shows a parts number for a replacement carb, currently NA. 80L-14100-03-00 (or 02-00) at more than $700 each!!
« Reply #4595 on: January 07, 2026, 04:47:38 PM »
Nice set!
+3!
Probably 4WD too.
Thanks guys, the manual B4 is going back to my son, he's loved it since he bought it 10 years ago, but it was a love/hate relationship because it always had something going wrong with it, due to the previous owners lack of maintenance. It's now going fine, and I recently had new timing belts and a new radiator and water pump/thermostat/hoses etc installed, and it's running great. He'd been driving it for a couple of weeks and the clutch hose popped, so it's back in the shop getting that fixed. Once it's done I'll take my auto B4 to the shop to get my Roadworthy Certificate and get it registered. I'm excited. ;D
Terry's B4's 3 by Terry Prendergast, on Flickr
Offline grcamna2
« Reply #4596 on: January 07, 2026, 06:44:32 PM »
Nice set!
+3!
Probably 4WD too.
Terry,you still have the small Ford UTE that had propane fuel;how's it running now as a gasoline powered vehicle ?
« Reply #4597 on: January 08, 2026, 02:20:19 PM »
Nice set!
+3!
Probably 4WD too.
Thanks Bill, I actually have two utes, one on LPG and the other on gasoline. They both go well, the LPG one is cheaper to run but I tend to drive the gasoline powered one more because it has a couple more creature comforts like a canopy that allows me to put bigger/bulkier items in it, cruise control and a radio that works all the time.
I’ll eventually sell the LPG ute, as I don’t drive nearly as much now that I’m retired, and it’s taking up space. I’d love to V8 swap it, I have an old 351 Cleveland engine that needs a rebuild, and it’d be fun to put it in my ute, but it’s one more project to add to an ever increasing list of projects that I’ll probably never get around to doing. ;D
« Last Edit: January 08, 2026, 02:30:40 PM by Terry in Australia »
Offline grcamna2
« Reply #4598 on: January 09, 2026, 12:25:57 AM »
Terry,nice to see you have two  :)
« Reply #4599 on: January 09, 2026, 01:41:43 AM »
Thanks Bill, they’re really handy for collecting bulky items. I had company supplied utes for 12 years and I missed them when I moved into a different job and drove sedans. I’ll definitely keep one until I have to hang up my keys in another 20 years or so. ;D
