Author Topic: What did you do to your non-motorcycle vehicle today?  (Read 278126 times)
« Reply #650 on: September 08, 2019, 10:12:13 PM »
no I got a gates brand pump 57 bucks,ive put a couple on this over the years,thats an aussie holden 308 cid
« Reply #651 on: September 10, 2019, 05:23:18 PM »
Borrowed a 4’ X 8’, vee nose, enclosed trailer from a good friend. I wanted a small, enclosed rig for a 4 hour trip this coming weekend (taking my 1970 cb750K0 to the Cobble Beach Concours). Spent two days power washing, cleaning out the “mouse house” stink and making it safe! Loose wheel bearings, missing “bering buddy” caps, burned out lights, bad grounds, flapping fenders, and a broken spring! Even did a bit of sanding and painting. Screwed in a wheel chock and added a couple of tie downs that are actually fastened to the frame (through the floor). What a slob! Guy owes me a lunch!
Offline jgger
« Reply #652 on: September 10, 2019, 06:21:24 PM »
At first I thought you were talking about the bike, I thought holy crap that thing wasn't even close to showing.
.............After my publick edumakashun wore off I realized that it was the trailer you were talking about. I always try to return borrowed things better than when I got them, you done good.
Good luck at the show and dont forget to take pics.
Offline Kelly E
  • Geriatric Hooligan
« Reply #653 on: September 10, 2019, 08:34:51 PM »
Nice job. I have done almost the same thing to a borrowed trailer before. I didn't want to have a problem when I was using it. I also like to leave it better than I got it and I figured if I needed it again it wouldn't be a problem. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #654 on: September 11, 2019, 06:11:04 AM »
Planning 8+ hours, towing my favourite bike, so thought I should have a look at the trailer......
Glad I did!
« Reply #655 on: September 27, 2019, 09:01:24 PM »
well you try and do the right thing and get #$%*?the 20 year old viscous fan clutch was a little wobbly on my car so I thought id do the right thing and replace it?so I get a dayco unit online delivered promptly and its way faulty!it felt firm by hand at first but now after 45 mins use its free wheeling!i got the motor well hot theres a super steep long hill around the corner I roared up twice and still no drive in the thing,when I shut the motor down the fan still spins like a top for a while,the old delco made in usa unit is going back on right now!i contacted the seller with this photo and an explanation,some times I guess if it aint #$%*ed don't fix it?i was trying to use the prevention is better than cure thing though?you can see the pulley and belt have stopped but the fan keeps on spinning!
Offline jgger
« Reply #656 on: September 27, 2019, 09:46:20 PM »
Last weekend I finally got the transmission out of my daughter's Jetta (A.K.A. Hitler). This weekend the fun continues. Timing chain is a real PITA on that thing, ran out of cuss words. Used all the ones I know in both Spanish and English at variable volume and combinations. Guess I am going to need to learn another language to finish it up!
Anybody who has worked on one of these 5 cylinder jobs, I'm open for any guidance.
« Reply #657 on: September 28, 2019, 10:03:39 AM »
 I'm open for any guidance...
Trade it asap!
Offline jgger
« Reply #658 on: September 28, 2019, 10:08:45 AM »
I'm with you, but it is already in pieces.🥺
« Reply #659 on: October 02, 2019, 03:05:42 AM »
Scrap metal dealer mate, and just remember, VW are sh1t........... ;D
Offline CBJoe
« Reply #660 on: October 02, 2019, 04:26:45 PM »
hey now...I love my passat....but i'm also not having to fix it  ;)
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline jgger
« Reply #661 on: October 02, 2019, 06:34:18 PM »
Joe, sorry but Terry is right on this one. They are a fine car as long as the only thing you open is the door or trunk anything after that is a nightmare.  No matter what you are working on there at least 3 or 4 unrelated things to remove and most of them take a special VAG tool #ou81too or some such thing! After working on Hitler's revenge I have come to understand that VAG stands for Volkswagon  Audi Garbage. Plus ALL the information for these things is top secret stuff and not for the common man to know.............but other than that I really like this car. NOT!
« Reply #662 on: October 03, 2019, 02:19:18 AM »
This is what we called Hitler's revenge in the army.  Just saying.  ;D
Offline spotty
« Reply #663 on: October 03, 2019, 02:40:01 AM »
Found out today it's going to cost at least $300 to fix the A/C on the clown car.....
This is why I didn't fix it 4 years ago when it crapped out,but Mrs spotty has decreed it will be fixed, so fixed it give a fcukwill be but I couldn't give a fcuk about it
The brakes however...... severely warped discs and severely reduced effectiveness, that needs looking at
And the there's the auto trans slips a bit when hoofing it up the hill I'm cursed to live on, that could do with some love
Oh yeah, the cracked rocker cover that sprays oil onto the exhaust manifold, doesn't bother me but it does worry onlookers when you pull up at the lights and clouds of oil smoke pour out from under the hood, looks cool but.....
Ah well, one thing at a time
i blame Terry
« Reply #664 on: October 19, 2019, 03:01:49 PM »
Changed the oil/filter on my 1980 FORD F350 plow truck. Mounted the Meyers Plow, added some hyd. fluid. It leaks a bit (self lubricating), but the whole thing just keeps on running! Won’t need it for a few months, but beautiful cool day, perfect for the job. Picture is typical January, 60 miles N.W. of Toronto.
« Reply #665 on: October 20, 2019, 12:58:56 AM »
That's a great looking truck! ;D
« Reply #666 on: October 20, 2019, 04:50:15 AM »
Thanks, Terry! The fenders and doors are all blistering rust again (replaced in 1999). Rotting fuel tank, lines and a few hoses recently. It pretty much stays on the property now. Not sure how much longer it will last, but I keep it rumbling along....... I was working in the Maintenance Dept at a SEARS wharehouse and actually picked it up new, late 1979. 20 years later, as the Regional Property Manager, I ran the demolition of the building. Bought it at an “Employee Sale”, with the Plow. It’s been at our Farm ever since...... Served us well and it even hauled my Legend Car, for a few years!
« Last Edit: October 22, 2019, 03:54:02 PM by BenelliSEI »
Offline jgger
« Reply #667 on: October 26, 2019, 07:22:59 PM »
Spent a little quality time with Hitler's revenge,  setting closer to leaving on it's own power!
Offline Kelly E
« Reply #668 on: October 26, 2019, 07:57:47 PM »
I spent the afternoon murdering blackberries with the tractor. Found 5' of driveway behind the shop that I forgot I had. ;D
1983 Honda CB 1100F
« Reply #669 on: October 26, 2019, 09:36:48 PM »
Drove by the Volkswagen plant in TN this past Thursday.
Wouldn't it need to be an original bug to be a Hitler's car (from that era)?
Must be a reason for Volkswagen being the cheapest of the VW/Audi/Porsche lineup... ;)
« Reply #670 on: October 26, 2019, 10:02:39 PM »
Not mine, but I looked at my buddys 40 ford project. There's not one part or panel that hasn't been tweaked. It's freaking amazing. 392 hemi efi stack injection, 5 speed, Hot Heads, Quick change rear, AC, Heat, chevy water pump, it's got it all.
  He put in water pump lube and no antifreeze just for testing. It ate through the new hoses and peppered his powder coated frame from droplets blowing back onto the frame. It got seriously flushed and a proper mix of antifreeze was added.
Offline jgger
« Reply #671 on: October 26, 2019, 11:41:24 PM »
Raf, I call it Hitler's revenge for a couple of reasons.  First of all my language is English, but I have depleted ALL the cuss words I know plus I have even resorted to re-using most of those words with an accent! I speak a little spanish and ALL the spanish cuss words have been used up also. Sometimes I get a little pissed off working on this thing, just a little.
Next is the oxymoron of "German engineering" . If there is such a thing as "German engineering" and it was used to build this car, then it was done for revenge for the U.S. and others kicking the German's asses in WWII! I'll give you an example of the stupidity of this car. The power booster for the brakes gets it's vaccuum from a pump that is driven directly from the timing chain. They fail and leak oil like the Exxon Valdes. It is held in place by 3 screws, however to remove it you must remove the transmission.  The cooler for the transmission is INSIDE THE TRANS so you need to drain the cooling system! But that's just a small portion of what needs to be removed for a simple job. Even more comes off to do the timing chains, like I'm doing.
So I have lovingly named this vehicle Hitler's revenge!
I know, it sucks to be me! Boo hoo hoo.😥
« Reply #672 on: October 27, 2019, 12:55:41 AM »
I understand frustration with car repair work...I know it all too well having wrenched on my cars for 35+ years. I used to own a 00 Crown Vic Police Interceptor in plain clothes markings. Pulled the timing cover and valve cover to access the chain. To get passenger side valve/cam cover off you have to drop the driver's side engine mount and remove it so the motor can be tilted over far enough to get the cover off. Fan and AC components are in the way. They changed it 3 or 4 years later I believe.  Chains were fine after all,  noise was misdiagnosed as coming from chain instead of the lifters.  Well, the motor's external top and front and part way down sides got a good cleaning and it needed it. Just a minor nuisance...
Good luck wrapping up the work on Hitler's Revenge.
« Reply #673 on: October 27, 2019, 12:57:06 AM »
I pulled my car off the car carrier tonight after driving it to Tucson from NE TN.
    • http://forums.sohc4.net/index.php?PHPSESSID=uceiqoq6fh5sm2j8v6hfiq8bo7&/topic,60973.0.html
« Reply #674 on: October 27, 2019, 01:46:10 PM »
fixed the handbrake..cabels..one vas not in order so made a new inner kabel..and reused the auter tube..solder the end knob on..to make it more safe...got s deer-gitter in the front..ve have a lot of heavy vildlife..and they crasch a lot of cars..aut here in the farm/contry side..
