Author Topic: What did you do to your non-motorcycle vehicle today?  (Read 173224 times)
« Reply #1600 on: January 12, 2022, 03:05:11 pm »
 I got a lovely gear pattern on the keeper 9" ford differential, for my firebird, the one made from the leftover parts was not so easy. A well-worn set of gears always seems to be a challenge to duplicate the pattern.
 Edit, I printed two sets of instructions for reference and one said to spin the gears with a drill motor. The pattern I was looking for appeared on the gears. The marking grease was almost hard, I mixed it with some wheel bearing grease, and it got a lot easier to see.
 I filled my new Harbor freight parts washer with detergent and water, I soaked an F0 head, and got it a bit cleaner. It had a missing tach seal and had covered itself with a nice coating of weatherproofing, but that's for the motorcycle thread.
« Last Edit: January 12, 2022, 04:53:50 pm by Don R »
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #1601 on: January 12, 2022, 04:30:41 pm »
Both rear tires on the car have a habit of losing pressure.  Its been a slow leak that's gotten nursed bi-weekly for a while.  But now with cold weather and less use - the rate of depressurization has advanced to 38 hours.
The easiest thing to do was replace the valve stem cores.  Will see of that makes things better.  Otherwise, the wheels may have to come off for service.
« Reply #1602 on: January 13, 2022, 05:25:54 am »
That attachment could come in handy, I also need to lift the bed off my dually to replace the brake lines.
I bought this gantry crane from Harbor Fraught  (or Fright) 3 or 4 years ago when they were still doing their 25% off coupons for about $500 out the door.  They've gone up a little since then but it is nicely made and has replaced my folding shop crane for most engine pulling work.  It has come in handy for a bunch of other things too, like unloading heavy stuff from trailers.  I'll be using it to pull the bed off the '81 Toyota pickup one of these days.
https://www.harborfreight.com/1-ton-telescoping-gantry-crane-41188.html
I bought the truck crane from HF and use it on my trailer for logging and other things.  It works reasonably well after I rebuilt the hydraulic cylinder.
« Reply #1603 on: January 13, 2022, 05:06:34 pm »
 I finally got a good pattern on the left-over parts 9" ford rear. The R&P is so worn in "the pattern is full, ghostrider"
 I'm tickled with what I think is the ultimate 9" ford third member, it's a decades long collection of parts and information. I remove the springs from the posi unit, they are mostly there for icy conditions and this car won't ever see ice, it's shimmed snugly but it should go around a corner with no chattering at all.
« Reply #1604 on: January 13, 2022, 05:22:28 pm »
Congrats Don!
« Reply #1605 on: January 13, 2022, 05:49:35 pm »
 Thanks David.
   I was admiring a truck crane a couple days ago. I have a cherry picker from a local farm store, I made a boom extension, and I can go 10' feet in the air now. It can get a little tippy so I put lead ballast on the rear when I use it. I can set a 750 on a 6' tall shelf. Less motor so far.
« Reply #1606 on: January 13, 2022, 07:24:00 pm »
This week I sold my 2015 Ford Territory SUV to my son. Part of the deal was that he traded me his 2002 Subaru Liberty (Legacy in the US) B4 twin turbo, plus some cash. (the car in the pic isn't mine, but it's the same colour with the same wheels)
Subaru Legacy B4 by Terry Prendergast, on Flickr
As much as I loved the Territory, it's a big arsed SUV and a pain to park in the little car parks in the streets around where I work, especially in the dark at 6am, when I go to work. My son, on the other hand, works in TV and the film industry, so needed a bigger car so he could carry all his equipment, so we did the deal. I've had the Territory since new and it was important to my boy to get a good used SUV with a known history, as all his other cars he bought used, and most (including the Subaru) have been pretty unreliable.
The Subaru has been breathed on by a PO, so instead of the 254 BHP of a stocker, we were told that it's putting out a tad over 300, at the wheels due to an ECU change, and some turbo tweaking. Today was the first time I'd driven it in years, and initially I thought that the turbo's weren't kicking in? Then I got in a situation where I had to merge into another lane (roadworks ahead) so I booted it, and FCUUUUUUK!!! The turbo's both work fine. ;D
« Last Edit: January 13, 2022, 07:28:59 pm by Terry in Australia »
« Reply #1607 on: January 14, 2022, 05:11:26 am »
Replaced rear shocks on our 2004 GC, the front still awaits me.
« Reply #1608 on: January 14, 2022, 09:07:51 am »
 When I loaded flatbed semi's we called this amount of cribbing an enemy buildup. Yes, that is a cb750 brake piston pressing the posi unit off the bearing.
Offline Kelly E
  • Geriatric Hooligan
« Reply #1609 on: January 14, 2022, 12:48:37 pm »
Nice 8)
I made some low sides to haul crushed rock for pothole patrol after the last round of snow and ice.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #1610 on: January 21, 2022, 01:14:38 am »
Installed a DRAC/VSSB module on the 93 Chevy 3500. Still no speedo or OD...
Back to the drawing board.
Attention now going to coolant temp sensor/thermostat and the TPS
Thinking now it might be 2 separate issues instead of one linked issue
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
« Reply #1611 on: January 21, 2022, 01:44:55 am »
i hate any car after about 1975,if it aint got chrome bumpers itll be a bear to fix when dumb #$%* goes wrong!
Offline ozm29c
« Reply #1612 on: January 23, 2022, 04:19:44 pm »
Greased the wheel bearings on the 32 bogey wheels, 4 return wheels, 2 track adjusting idler wheels and finally the drive sprocket wheels on my Studebaker Weasel. Hours of unmitigated fun.
« Reply #1613 on: January 24, 2022, 05:56:01 am »
That would get some attention down at the ice cream shop !!
Online BenelliSEI
« Reply #1614 on: January 25, 2022, 06:07:11 pm »
Installed a new battery and got it running. A guy came to see it and I think the truck is sold.
1917 REO Speedwagon.
Offline bear
  • Leeton in Australia
« Reply #1615 on: January 25, 2022, 07:38:48 pm »
 ;D
Don't look at me. I'm fluked if I'm gunna fix it for ya. ;D
Offline bear
« Reply #1616 on: January 25, 2022, 07:40:11 pm »
You lucky lucky bastard!
« Reply #1617 on: January 26, 2022, 12:41:48 am »
Nice! The car is long forgotten, and the band who adopted it's name is not far behind now, but it's fantastic, to me at least, to see a 100+ year old vehicle still running, and still capable of performing it's original design brief. My cousin's daily driver is his 1928 Dodge "Fast Four" that he restored when he was 15. I think he's 65 this year, but he and his old Dodge are still going strong. ;D
Online BenelliSEI
« Reply #1618 on: January 26, 2022, 05:57:32 am »
Terry…… 1918 Dodge. Part of same collection. Really fine automobiles!
« Reply #1619 on: January 26, 2022, 07:46:17 am »
Since we're talking antiques, here is my buddies 1925 Ford!  [prolly only the frame is from 1925?!]
Has a [GASP!] Chevy 454 big block with dual carbs and a 671 blower.
My "butt dyno" says it's putting out 500hp.
Last time we started it, it developed a fuel leak with one of the custom fuel lines fittings, I've offered to repair it for him [so I can drive it again!]
« Reply #1620 on: January 26, 2022, 01:11:49 pm »
lol! built ford tough...using chevy stuff!
« Reply #1621 on: January 26, 2022, 03:40:47 pm »
 Our race car has a big block chevy and powerglide with only 3 genuine chevrolet parts. They are in the transmission.
  I picked up a tube of 1/16" 308 stainless steel welding rod for the exhaust on the firebird. It went bad on the last weld and I'm having a hard time getting started again.
« Last Edit: January 26, 2022, 03:44:14 pm by Don R »
« Reply #1622 on: January 28, 2022, 09:58:47 pm »
bout 6 or 7 years ago i fitted new rear drums shoes and cylinders on my daily driven 1973 holden premier,id only done adjustments in that time so thought id have a look inside,still look great after a hose out with good old ct18 truck wash,a quick refresh partial bleed and good for another few years?those old PBR self adjusting drum brake assemblies are a complicated unit,still after all these years i do one side at a time so i can copy the other side on reassembly,disc units are dumb arse easy?plus you dont need the good hook tools for those #$%*ing springs?
« Reply #1623 on: January 28, 2022, 10:08:46 pm »
Dave,you treat your brakes nice:they'll save your life when called upon.
« Reply #1624 on: January 29, 2022, 01:11:31 am »
hopefully,show these to a young brake technician and he will #$%*?
