Author Topic: What did you do to your non-motorcycle vehicle today?  (Read 333091 times)
0 Members and 10 Guests are viewing this topic.
Offline Kelly E
  • Geriatric Hooligan
« Reply #3825 on: November 09, 2024, 08:32:23 AM »
Price of old used trucks in good shape is absolutely through the roof...some selling for more than their new price!
I'm not selling mine, I bought it 26 years ago for $16k. It was all stock and non turbo. I put a Banks turbo kit and better radiator on along with the a stage 1 towing transmission with a double clutch torque converter to back up the suspension mods. I spent almost $10k on the mods. It now has 142k miles and is a working beast. It would likely cost at least $80k to $90k to replace it with a modern truck that probably won't outlive this one.
old heavy duty basic tech stuff like that lasts forever as we all know,i drive modern heavy duty trucks for a living and they go into limp mode and what not for no #$%*ing reason other than a sensor or some other annoying #$%*,i used to drive old macks and worst thing might be two injector lines rubbed together and through but easily fixed with bronze over repair till new line made or purchased?plus I miss that old rolling coal!!
I used to drive big trucks too. I've driven most of the major brands like Kenworth, Peterbuilt, White, Freightliner, Mack, International, Ford, GMC and Volvo. My favourite truck was a 79 Freightliner conventional with a Detroit turbo supercharged 8V92 and a Road Ranger 13sp.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline simon#42
  • liverpool
« Reply #3826 on: November 10, 2024, 10:25:09 AM »
cliff have you read the title of this thread !
« Reply #3827 on: November 10, 2024, 10:30:03 AM »
I've sprayed semi-gloss engine paint,both Duplicolor and VHT also VHT caliper paint.
I like using the semi-gloss because I oven-cure it for an hour at 200 degrees Fahrenheit which gives the semi-gloss a nice hard near-gloss similar to OEM black engine paint after I remove it from the oven.
I like how your polishing of the OEM black has turned-out.
Offline Magpie
« Reply #3828 on: November 10, 2024, 10:52:19 AM »
Simon, I'm in too much of a hurry today. I'll move it.  :D ::)  Cliff.
« Reply #3829 on: November 13, 2024, 05:44:43 AM »
Grand Cherokee would not start, after replacing the battery I tracked it down to Neutral safety switch; with key in run position I am able to jump start it.
Funny thing - it happens with hot engine only, cold engine starts every time.
« Reply #3830 on: November 13, 2024, 06:51:44 AM »
Sounds very odd!
« Reply #3831 on: November 13, 2024, 09:00:23 AM »
Might have sludge on switch that gets sticky when hot and it shrinks when cold allowing the switch to function.
« Reply #3832 on: November 13, 2024, 11:46:11 AM »
Sounds very odd!
It took me a while to reproduce it.
« Reply #3833 on: November 13, 2024, 11:47:20 AM »
I plan to get it on ramps today and take a look.  Technically I could just bypass it.
« Reply #3834 on: November 14, 2024, 11:01:07 AM »
If I remember correctly, that’s what I did on the old Cherokee Sport.
« Reply #3835 on: November 15, 2024, 03:03:46 AM »
i had to toot my car horn today,it has twin old school metal housing two tone horns from the factory that sound deep n loud and nothing like modern high pitched squealing #$%*es,one went out during that toot,i opened it up and found a broken solder joint,easy fix plus cleaned the contacts up,tuned it up and just as good as when it was made in 1973!cant beat these old "snail" horns unless you run truck air horns?
« Last Edit: November 15, 2024, 03:07:33 AM by dave500 »
« Reply #3836 on: November 15, 2024, 04:13:57 AM »
I sprayed the bejeesus out of it with contact cleaner and - knock on the wood - seems to be working now.
« Reply #3837 on: November 15, 2024, 04:15:00 AM »
Great job, I love repairs like that.  On an old, well built item.
« Reply #3838 on: November 15, 2024, 05:10:05 AM »
“Don’t fix what ain’t broke!”
« Reply #3839 on: November 15, 2024, 03:23:16 PM »
Nice !  ;) :)
« Reply #3840 on: November 15, 2024, 09:40:33 PM »
further to car horns,my wifes new to her 2015 mazda 3 only has one low tone horn from the factory and its like a warm flat low alcohol beer!!,on forums even the higher end 3s only had one anemic horn and its a thing on forums how to add or replace the horns,they all say you HAVE to remove the entire bumper and grille assembly and youtube shows how etc,i had a very similar size Fiaam brand horn sitting around and managed to with some fangling and reaching through the lower chin grille get it up into position quite easily,i trimmed bout 3mm off the widest part of the trumpet mouth and cut the mounting stud as short as i could and still get 4 or 5 threads holding,then with ninja stealth and English Winston Churchill never give up attitude and a telescopic magnet managed to Houdini the second horn into place!#$%*!why dont they just put twin horns on them?i thought its kinda normal on cars?
« Last Edit: November 15, 2024, 09:48:37 PM by dave500 »
« Reply #3841 on: November 16, 2024, 11:02:02 AM »
Dave,how does your Mazda sound now with two good horns ?  :D
« Reply #3842 on: November 16, 2024, 12:57:06 PM »
it sounds assertive now Bill.
« Reply #3843 on: November 16, 2024, 02:56:24 PM »
Lol  ;D
I remember installing a pair(solenoid also)of red Fiaam? horns on a 1974 BMW R90/6 and the change in sound compared to stock was astounding;sounded louder than an automobile. !  :o
« Reply #3844 on: November 17, 2024, 01:21:15 AM »
absoloutley Bill,if ya hitting your horn ya gotta be heard.
« Reply #3845 on: November 18, 2024, 07:36:00 AM »
Most cars do have two horns, Dave, maybe Mazda used one to save money?
Offline britman
« Reply #3846 on: November 21, 2024, 07:05:11 AM »
I changed the cabin air filter in my 2022 GMC pick up.  About 15 bucks for the filter and my labor was free and it took a total of ten minutes.   The last time I had it the dealer they wanted $179 for the procedure.  I really empathize with the mechanically challenged folks who go to these places.
« Reply #3847 on: November 23, 2024, 02:05:24 AM »
i replaced the wiper blades on my wifes new to her 2015 mazda 3,i looked at the wiper arms and thought what the hell?im used to open old school stainless steel arms,these are no different,just slip new ones in.
« Last Edit: November 23, 2024, 02:10:41 AM by dave500 »
« Reply #3848 on: November 24, 2024, 09:47:48 PM »
 I bought a Bosch O2 sensor for $25 off of ebay, it's likely a clone but for the price I wanted to see it. The ad shows the Bosch box. Holley wants $145 for them, my holley efi, Racepak data recorder and Autometer wide band A/F meter all use a similar sensor, this one is supposedly a better sensor. We shall see.
 Mostly I want to learn what sensor comes with which plug and get familiar with the non-Holley alternatives. If the plug and the thread work I'll likely spend more for a genuine store-bought Bosch.
« Last Edit: November 24, 2024, 09:54:03 PM by Don R »
« Reply #3849 on: November 24, 2024, 10:52:44 PM »
You want to sort-out the fuel injection on your race car before going back to carburetors Don ?
