Author Topic: Kickstand/ center stand help  (Read 909 times)
Offline GardenGnome
  • 1977 CB550F
« on: March 17, 2018, 10:52:27 AM »
I am wondering if someone may be able to help with the location of the metal half moon looking piece that connects the stand to the spring? I am sure I’m not being very articulate, but I am not sure how else to explain. The images on cmsnl don’t provide enough description to finish this task. Thank you.
If I've learned anything about building a motorcycle, it's check and re-check your work before you put it all back together. Although you do gain more experience by doing it twice.
Offline 38rudge
Re: Kickstand/ center stand help
« Reply #1 on: March 17, 2018, 11:33:26 AM »
It's part No: 50523-300-010
Offline Johnie
« Reply #3 on: March 17, 2018, 02:16:39 PM »
Are you asking about the location on the bike? If so, look at the cross member under the bike behind the tranny. You will see a hook off the top. The half moon goes there and the spring in the smaller bottom hole on the half moon.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline GardenGnome
  • 1977 CB550F
« Reply #4 on: March 17, 2018, 03:55:16 PM »
Thanks for the help you guys, got it figured out.
