Author Topic: CB750K K7 unidentified wire  (Read 1295 times)
Offline Erny
« on: March 12, 2018, 01:20:49 PM »
After replacing steering stem bearing and front end cleaning, I just started to re-connect all electrical connections on the bike front (in the headlight) and found 1 wire I'm unable to identify where it belongs to.
It is brown/white wire coming from combined turn/light/horn left handlebar switch , most right on attached picture.
Checking wiring diagram there should be no such wire??? (diagram attached). Diagram is from original owners manual and the same is in shop manual (K7 supplement info part). Diagram shows 10 wires but I have 11...
Bad is that wire was connected somewhere (has scratches on connector) but no idea where..
Does anybody have any info about it? Bike is K7 (model 1977), manufactured 10/73, all original.
Thanks
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline Johnie
Re: CB750K K7 unidentified wire
« Reply #1 on: March 12, 2018, 01:30:56 PM »
That wiring diagram shows that wire marked Br/W.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Paintedseat
« Reply #2 on: March 12, 2018, 02:02:40 PM »
Is it not the turn signal buzzer
Offline Johnie
« Reply #3 on: March 12, 2018, 02:13:52 PM »
Back when I had a K7 I do not recall a turn signal buzzer on it. Looks to me like it is going to a lamp. Maybe a turn signal lamp on the dash?
Oshkosh, WI  USA
Offline Flyin900
« Reply #4 on: March 12, 2018, 02:39:26 PM »
There is a brown/white shown on the gauge cluster lighting on the diagram, so do you have those wires connected to your gauge cluster lighting connected to a 12V source?
This is another possibility if there is no apparent connection for that wire on your bike
I went through the same thing recently when I substituted a left hand signal/headlight switch from a 1976 Goldwing to a CB400F that I was doing. I wanted the clutch perch that was part of the switch on the Goldwing switch assembly and there were two extra wires in there vs the original CB400F switch assembly. One wire was for the turn signal buzzer used on the 76 Goldwing and also on some early CB750's too.
So unless your the original owner of this bike from new chances are some PO substituted that switch onto your bike and the scratches are from when it was supplying a service to the correct bike it came from originally. Just tape it off if you can't see a use for it; as I did that on the CB400F and every circuit and accessory works correctly with only the original wires connected properly.  :)
« Last Edit: March 13, 2018, 10:50:00 AM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline Johnie
« Reply #5 on: March 12, 2018, 02:43:02 PM »
Sounds like a good plan to me.
Oshkosh, WI  USA
Offline Mr. Mike
« Reply #6 on: March 12, 2018, 05:09:27 PM »
Yep,
Check your speedo and tach gauge lights in the dark, looks like it might be it (according to the online diagram compliments of Oregon Motorcycle Parts. My ‘78 CB blinker buzzer is Br/Bl. The wire being a male end, check your tail light too.
2002 Electra Glide
1978 750K
1966 CL77 (sold)
2020 CB500X
Offline Erny
« Reply #7 on: March 12, 2018, 06:25:35 PM »
Speed and tacho are ok, have power.
This wire looks like as redundant. Hard to believe that PO chaged switch, bike has only less than 9000miles
Offline Phinn
  • Subversive
« Reply #8 on: March 13, 2018, 08:32:16 AM »
The 77 and 78 have an unused connection up front. For some accessory that didn’t get into production.
1978 CB750K -- "Mouse," a former basket case, resurrected
Offline Airborne 82nd
« Reply #9 on: March 13, 2018, 10:03:04 AM »
I think that was for a parking light on top of the headlight shell not used on USA bikes,
Offline Erny
« Reply #10 on: March 13, 2018, 10:46:35 AM »
No it isn't. Parking light has the same connector - male. Other end should be female...
« Reply #11 on: March 13, 2018, 10:52:34 AM »
Do I see a black wire in the back ground with brown and white bands? Or is that orange and white?
Offline rotortiller
« Reply #12 on: March 13, 2018, 11:29:29 AM »
The Brown/White from that switch goes into a female multi connection bullet connector.
There is also another jumpered Brown/White multi bullet connector in the headlight bucket with a brown/white with black band with black wire crimped to it. Instrument lights go to this one. If you want look at the pic it follows the 1977 wiring diagram for the jumper.
« Last Edit: March 13, 2018, 12:29:02 PM by rotortiller »
Offline Erny
« Reply #13 on: March 13, 2018, 04:43:49 PM »
Mystery solved today - that wire should be connected to brown wire from main cable bunch coming from back of the bike in order to power position lights in front flashers
This connection is not at all shown in wiring diagram...brown connector is shown as not used.
Anyway thanks for help
« Last Edit: March 13, 2018, 04:45:38 PM by Erny »
« Reply #14 on: March 13, 2018, 06:12:49 PM »
I thought for sure it was the optional CB radio!
Offline Can550
« Reply #15 on: March 13, 2018, 10:21:51 PM »
European headlight version used it
Offline Phinn
  • Subversive
« Reply #16 on: March 14, 2018, 04:23:10 PM »
It was for the combo CB radio/GPS/Super-computer system. Like on Captain America’s motorcycle. A very rare upgrade.
Offline robvangulik
  • Honda Fourever
« Reply #17 on: March 14, 2018, 05:18:55 PM »
European bikes have no position lights.....not in the 'flashers' , but they do have parking lights.
Offline jgger
« Reply #18 on: March 14, 2018, 08:38:44 PM »
It's an underwire for a bra, did you misplace the Victoria Secret model that it was connected to?  That's why you should label everything as you take it apart.
« Reply #19 on: March 14, 2018, 10:43:36 PM »
Open switch and see where it is connected and how it will get 12V. I did that with all wires before connecting them when I restored my K6. Marked each wire with tape from both controls and matched them with main harness.
