Author Topic: Electrolysis- rust removal  (Read 937 times)
Offline JonathanHValencia
« on: March 17, 2018, 12:23:19 PM »
Hey folks,
I’m doing electrolysis on my tank as I type this. I need advice on how to prevent the flash rust once I’m done here.
Once I completely dump out the rusty innards and solution left behind, what do you guys use to rinse and prevent any flash rusting?
The tank will not sit, I’m going to install it on my bike tonight or tomorrow.
Re: Electrolysis- rust removal
« Reply #1 on: March 17, 2018, 12:51:50 PM »
How do I treat with prep n etch?
Just let it slosh around and sit?
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #2 on: March 17, 2018, 01:43:27 PM »
Yes. Fill the tank, let it sit overnight, and drain, rinse, and dry immediately, with hot air preferably. Then use the two-stroke oil mixed with gas, to rinse and coat. The Prep-n-etch gives an iron-phosphate coating that works well, and it removes any rust left in there.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
« Reply #3 on: March 17, 2018, 02:01:07 PM »
Hey Yamahawk. Rinse afterwards with water?
I just de-rusted with electrolysis. I just did this to prevent the flash rusting
Online rotortiller
« Reply #4 on: March 17, 2018, 02:05:45 PM »
I use muriiatic acid to get rid of rust, then rinse the stuff out soap and water. Then I use Por15 metal prep. After that it gets rinsed and sprayed with oil mist until I put it in service unless I decide to use a tank liner. It is a quick and clean fix for moderately crappy fuel tanks. I tried the metal rescue route and found it  took too long with moderate results. The acid is the way I shall go from now on and it is much cheaper to do in my case. Both were done several months ago.
« Last Edit: March 17, 2018, 02:08:04 PM by rotortiller »
Offline beemerbum
« Reply #5 on: March 17, 2018, 02:37:55 PM »
Fogging oil spray in the tank works well. Try not to blow the little red plastic straw into the tank. Don't ask.
Offline Yamahawk
« Reply #6 on: March 17, 2018, 02:45:11 PM »
yep, the Prep-n-etch gives the protective coating, but rinse well with hot water and dry immediately. Follow with oil fog or fuel - oil mix.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
