Author Topic: engine's out what should I replace?  (Read 1412 times)
Offline Wbflyer
« on: March 17, 2018, 05:39:16 PM »
Since my engine is out, i figured I could change the starter and points to electronic.  Thoughts on moving to electronic points?
Re: engine's out what should I replace?
« Reply #1 on: March 17, 2018, 05:43:42 PM »
 This could possibly get kind of popcorny  ;) . There are definitely two camps,those that like their stock points and others who love their electronic stuff.
Offline Wbflyer
« Reply #2 on: March 17, 2018, 05:52:17 PM »
Gotcha.  Well, I am ok going either way so no worries.  It's just out so might as well do some stuff while it's out.   Need a new exhaust too.  want a black 4 into 2.  any suggestions?
« Reply #3 on: March 17, 2018, 06:06:07 PM »
Is the motor a leaker? If yes, replace the pucks and gaskets.
How was it running?
Replace the old paint with a nice new coat...
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #4 on: March 17, 2018, 06:12:50 PM »
Yup,
   But.... you could get both camps by getting Hondaman's electronic ignition conversion, it keeps the stock points, and they switch a transistor on the circuit to power the coils... the points last forever (almost), and you have the advantage of this millennia technology (almost) lol. And, you get rid of the condensers also, I believe... Oh, and when you get done, replace the engine ;)
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
« Reply #5 on: March 17, 2018, 06:16:53 PM »
 Just out of curiosity what size and year engine is it ?
« Reply #6 on: March 17, 2018, 06:46:05 PM »
Yeah cuz guessing at size and condition of something we can't see is bending my mind..
Offline setdog
« Reply #7 on: March 17, 2018, 08:05:07 PM »
why did you take the engine out?
cant you change the starter and the points with the engine in the bike?
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
« Reply #8 on: March 18, 2018, 01:15:19 AM »
yeah toss the points and use a modern fully electronic set up,less hassles.
Offline DaveBarbier
« Reply #9 on: March 18, 2018, 04:27:19 AM »
Need more info. What bike, what was the reason for pulling the motor, hoe much $$ do you want to spend, was it running prior to removal, what’s the goal (track bike, daily driver, weekend warrior)?
Having the motor out doesn’t help the installation of electronic ignition, it actually hinders it :). If the starter sounds when you connect it to the battery then it’s working.
I say keep points if they’re in good shape because there’s nothing wrong with points. Aside from cleaning the exterior and replacing leaking gaskets that’s about it. These motors are very reliable and few aftermarket parts are better than the old OEM ones that are currently in there.
Offline Deltarider
« Reply #10 on: March 18, 2018, 04:33:20 AM »
What bike?
CB500K2-ED Excel black
Online PeWe
« Reply #11 on: March 18, 2018, 06:59:51 AM »
The ignition can be changed any day when engine is in. If engine is out, there is a reason for it, right? Or only repainted the frame?
Open valve cover and inspect. If it has leaked oil, check the leak and replace gaskets.
Long time used might need new chains inside if rattling.
If it runs fine, no leak.... maybe a paint tune up only. I use rattle can spray that work fine without need of baking it in an oven in over 100C, maybe closer to 200C.
Ignitions have different users.
Racers that want the best performance with need of tuning the advance curves. Throttle sensor reading the throttle lift connected to an ign module. The advance might not need to be advanced  with increasing rpm's only, maybe a little bit retarded at a certain rpm later on too.
or people that like the old tech stuff that can be a vital part of the bikes heart.
or others that do not have time or have got the feeling for how the old points should be set and maintained.
or combo between old tech and new.... Hondaman's ign module.
Another thing is trust, if you have plans to take bike on a long ride and need to trust the electrical system that has to cope with heat, cold and maybe water.
There is no right or wrong (except for not adjusted ignition), follow what your need tells you and maybe your heart and eventual love for the bike from the old days with the old survived tech, still working :)
Many restores nowadays are restomods where new tech is implemented in the old vehicle. Like old US muscle cars, replacing an old fuel drinking V8 with a new modern V8 with much more power, cleaner and leaner + replacing bad drum brakes with discs + new suspension.
Up to the owner.
Fun to discuss though! ;)
« Last Edit: March 19, 2018, 10:44:04 PM by PeWe »
Offline Wbflyer
« Reply #12 on: March 18, 2018, 07:24:43 PM »
Sorry, it's a 1978 CB750.  I am restoring it and bought it from a guy already all apart.  They changed the rings and that is all.  At this pint, I'll try an run it and see what happens.  BUt might change to electronic ignition now.  It has roughly 36K miles on it.
« Reply #13 on: March 19, 2018, 09:39:59 PM »
 Hopefully it has new gaskets, was honed and has new nickel washers under the cam towers.
