Author Topic: Wire issue in engine chain sprocket housing  (Read 2950 times)
Offline Xander^
« on: March 20, 2018, 07:40:20 PM »
So i took off the cover to clean the chain sprocket and surrounding area.. and i think i may have disconnected a wire plug from the bunch that sits in here..
Im not educated at all in the wiring department and not sure what to do with this.
Should i just electrical tape the wire where the copper threads are exposed and plug it back  into the “female” type socket?
1977 CB750K cafe
Offline scunny
  • don't call me expert
Re: Wire issue in engine chain sprocket housing
« Reply #1 on: March 20, 2018, 11:28:32 PM »
That be your alternator wiring, check for broken strands etc. If good, I would insulate them with the high temp cloth stuff they are all ready covered with. available from a good electrical wholesaler. here in NZed anyway
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: March 21, 2018, 03:58:59 AM »
If we are talking about a CB750 then based on what I can see regarding the condition of your harness at this location of high amperage alternator connections I would do two things:
1) Replace the "sub harness" between the alternator and the main harness. Parts-n-More part number #24-4021
http://www.partsnmore.com/parts/honda/cb750k/?q=24-4021
2) Replace the female connectors on the high amp yellow wires from the stator:
This will help stave off electrical gremlins at this weak point in the wiring harness. I usually replace the male and female bullet connectors on the yellow wires at this location of every CB750 I lay my hands on. The old insulators are typically fused together and have to be cut apart. I cut the old connector off right at the crimp and only sacrifice less than 1/4" of wire that way. The female connectors from the stator are a little tough to do in place (without removing the trans cover or stator) but it can be done.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #3 on: March 21, 2018, 05:54:22 AM »
+1 on Wilbur's link to his crimping terminals, it is the ONLY way to go, don't try this with the ones you can buy at the auto parts electrical section, they are not good for much. You can find the crimpers on eBay, or at a wire supplier, mine are made by a company called PICO, and are made similar to Wilbur's ones, and produce a factory crimp with the type of OEM terminals we both use. I found a good supply of terminals for bullet and spade on eBay Cheap, and they work well. I also got the harness from 4 into1 from the alternator to the bike harness, and replaced ALL the bullet terminals at the wires in your picture. Made a world of difference.
The crimpers are an investment, and you can use them on any of your wiring harnesses if you have more than one bike. WAY better than the cobbled up repairs I have come across from PO's butcher jobs lol...
Here is an example of terminals you can get cheap... but might have to wait a couple weeks if from China lol
https://www.ebay.com/itm/40Pcs-Bullet-Male-Female-Terminal-3-5mm-Connector-with-Insulated-Cover-New/112576824476?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline RandomOrbit
« Reply #4 on: March 21, 2018, 06:18:58 AM »
OR Buy it here for ten bucks! http://4into1.com/alternator-wire-harness-31110-300-154-cb750-1969-1978/
CB750k6 owned since 1991
« Reply #5 on: March 21, 2018, 06:33:50 AM »
Even better!  8)
TAMTF...
Wilbur
Projects:
Offline Yamahawk
« Reply #6 on: March 21, 2018, 06:44:46 AM »
THAT'S the one I got, from 4 into 1, but it was more like $11... hehe.
Edmund Burke
Romans 8:28
Job 13:15
Offline RandomOrbit
« Reply #7 on: March 21, 2018, 07:56:38 AM »
I've got the same one. It was a Christmas present from my sweetie. It'll probably go on this weekend. I'm hopeful it will finally cure the phantom neutral light problem that has plagued me for years and likely help the weak charging too.
Offline przjohn
« Reply #8 on: March 21, 2018, 08:19:06 AM »
Vintageconnections.com has the tool and connectors you need. They also have nice kits that are nice to have in your shop.
« Reply #9 on: March 21, 2018, 09:13:34 AM »
+1
They are my "go to" for connectors. Be sure to get the 3.5mm bullets to fit the 70's (and many later) Hondas. The 4mm bullets are bigger than the 3.5mm connectors that are used on the SOHC/4's.
TAMTF...
Wilbur
Projects:
Offline Xander^
« Reply #10 on: March 21, 2018, 01:02:55 PM »
+1
Super helpful guys! Thanks a bunch. 4into1 cart getting heavy hehehe
1977 CB750K cafe
Offline boaf
« Reply #11 on: March 21, 2018, 05:32:08 PM »
Every order I make there is $200 minimum...just like Costco.
Build Thread '78 CB550K Four 'Phoenix' - http://forums.sohc4.net/index.php/topic,171255.0.html
