This is a new leak. When I put it on the side stand after riding the leak is almost immediate. On the center stand, not so much. I can't tell if it's coming from the screw pictured or from the bottom of the head where it meets the case. L side as you're sitting on the bike.
My suspicion is that it's the latter, and maybe a problem with the pucks. I've never had this cover off, so maybe there's a seal back there to replace? That'd be happy time, but, if it's pucks then I have to pull the engine since they're at the bottom of the cam towers.
Just looking for any insight at this point, if it's a common issue.
