Author Topic: Road racing final drive gearing??  (Read 5905 times)
Offline Rocketman
Re: Road racing final drive gearing??
« Reply #25 on: March 29, 2018, 07:03:57 PM »
The fronts I sourced from Sprocket Specialist use the stock Honda retainer that fastens to the sprocket with two 6mm bolts.  Can't recall ever closely comparing them to a OEM Sprocket to see if there were any differences.
« Reply #26 on: March 29, 2018, 07:29:21 PM »
That's good about using a stock retainer, early ones didn't. I prefer a thicker spline section, not always easy to find.
Offline slikwilli420
  • Master of Disaster
« Reply #27 on: March 30, 2018, 04:11:16 AM »
PBI was the original supplier of my 17 tooth front through rebel gears. They had the thicker flange at the spline. I'll try them and report back.
Offline gschuld
« Reply #28 on: March 30, 2018, 06:37:59 AM »
FWIW, at Mosport(2016), both of Harry Peters cb750 racers ran 17/46, while a stable mate in the 412 bike(with factory carbs) ran 17/47 gears.  Mosport is considered a fast track by most on account of the LONG slightly uphill section(+/- 130mph by the end).  The Harry Peters bikes(both factory frame and the Rickman) were fast...
George
« Last Edit: April 12, 2018, 11:04:39 AM by gschuld »
« Reply #29 on: March 30, 2018, 11:28:16 AM »
That's helpful George. Justin's #412 is a nearer stock engine, but Harry's is the same size bore Matt will use. I think Justin should use an larger rear for there.
