Author Topic: Am I doing this clear tube test right?  (Read 2241 times)
Offline Dos
  • Owner of a cb350f
« on: March 28, 2018, 04:27:14 PM »
Just wanted to get the OK that I’m doing this right.
Is it a coincidence that two and three are about the same just because they are the most and inner carbs? Or are they both just incorrect?
Online Don R
Re: Am I doing this clear tube test right?
« Reply #1 on: March 28, 2018, 04:39:52 PM »
 Turn off the fuel supply, drain some out and locate the clear tube so you don't need to move it. Then slowly turn the fuel back on. Observe the level. Every time you lower the tube, the float adds fuel to fill the tube. Then when you raise it the fuel is trapped there.
Offline Dos
  • Owner of a cb350f
« Reply #2 on: March 28, 2018, 04:50:46 PM »
So I did it incorrectly and should do what you mentioned correct?
Offline Gene
  • Chat enuf you too can be a
« Reply #3 on: March 28, 2018, 04:55:43 PM »
yes.
*1973 CB750K3 (Bow)
Offline Dos
  • Owner of a cb350f
« Reply #4 on: March 28, 2018, 05:04:12 PM »
Got it so bare with me here:
Drain everything out. Locate the hose and watch as the gas fills it.. then while the petcock is still on and the gas has filled all hoses , raise the hoses slightly and then lower back to where it was originally and that will be the correct measurement.
Right?
Offline markreimer
« Reply #5 on: March 28, 2018, 08:18:40 PM »
I tried the tube version a few times and got inconsistent results. Then i tried the “bowl” method and had great results. One carb body at a time. Take the bowl off and use a glass or plastic bowl. I used a little Tupperware thing. All that matters is that the bowl rises above the carb gasket surface. Turn on the fuel, watch the float slowly go up and stop. It should stop with the fuel about 2-3mm below the gasket surface.
I set the levels using the manual method as per the manual first.
I found I had one float with a bad pin using this technique. It was pitted. Replaced it and I now have four totally even carbs. The other three were bang on from the manual method (just using a ruler set to whatever tha manual said)
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #6 on: March 29, 2018, 01:44:58 AM »
That's a really great idea, Mark! Now if we could pinpoint the Tupperware bowl SKU hehe or what model # they sell it under, I am sure there are ladies out there that would sell a bunch!
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline DaveBarbier
« Reply #7 on: March 29, 2018, 02:18:39 AM »
Drain everything out. Locate the hose and watch as the gas fills it.. then while the petcock is still on and the gas has filled all hoses, raise the hoses slightly and then lower back to where it was originally and that will be the correct measurement.
Right?
NO! Once the fuel is on, don’t touch the hoses. Get the hoses in place and leave them there. When the hoses are filled with fuel, look at them, don’t touch them.
Offline Deltarider
« Reply #8 on: March 29, 2018, 04:06:31 AM »
Right?
Why 'don't touch them'?
CB500K2-ED Excel black
Offline DaveBarbier
« Reply #9 on: March 29, 2018, 05:41:51 AM »
Right?
I just said don’t touch because, unless I misunderstood, he thinks he has to raise and lower the tubes once he turns the fuel on. All you do is read the level in the tubes once you turn the fuel on. No raising or lowering. I actually do flick the tube a bit to make sure there’s no trapped bubbles, like a nurse about to stick you with a needle.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #10 on: March 29, 2018, 05:52:37 AM »
Right?
or a smack addict about to shoot up if that's a better visual.
cb750 k6 - ugly
Offline DaveBarbier
« Reply #11 on: March 29, 2018, 05:53:55 AM »
I just watched your videos, Dos. The inner carbs are too high. As long as the carb rack is level, it doesn’t matter if you hold it against the outer carbs or the inner carbs. The level will be the same.
I didn’t notice what your fuel source is, but I assume it’s the tank which is right next to it. That works. As others have said, get the tubes in place first before you turn the fuel on. Don’t go moving the tubes about.
So with empty carbs connect the tubes>tape them or something so they’re in a good place to measure the level>turn the fuel on and watch the fuel fill up the tube>measure to be sure it’s the proper distance from bowl seam.
Offline DaveBarbier
« Reply #12 on: March 29, 2018, 05:54:50 AM »
Right?
Haha, true. Just don’t go heating up the fuel in a spoon first.
Offline slikwilli420
  • Master of Disaster
« Reply #13 on: March 29, 2018, 05:55:30 AM »
This is pure genius and I believe I will never use the clear tube method again because this is easier and doesn't involve all of the uncertainty that seems to surround the tube method. Well done!
Offline markreimer
« Reply #14 on: March 29, 2018, 10:39:19 AM »
I read about it here somewhere a year or two ago. It’s great! The middle two carb bodies are a bit trickier as your bowl needs to fit in that small space. I trimmed the lip off my plastic clear bowl to make it fit. Anyway, really quite simple and effective. No more overflowing carbs since I did this.
Offline tlbranth
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline markreimer
« Reply #16 on: March 31, 2018, 10:07:53 AM »
That’s the thread!!
