Author Topic: What worked for my 1977 CB750K with pd41a carbs.  (Read 581 times)
Offline Paintedseat
« on: March 29, 2018, 01:51:17 PM »
Ok these carbs seem to give their owners some trouble. I am just going to post what I did to mine because it runs great finally! I have stock airbox and a MAC and 4 to 2 exhaust. I have 38 pilot jets. 115 main. The needles are on the 4th slot. One important detail is to make sure you accelerator pump rod is in contact with the arm. It runs amazing and I can't believe it's the same bike I have been working on. It pulls all the way to 8k hard.
Offline Mr. Mike
Re: What worked for my 1977 CB750K with pd41a carbs.
« Reply #1 on: March 29, 2018, 08:20:39 PM »
My 78 CB ran really well too...once warmed up. 100% stock
Took about 3 miles before it would idle fine (choke open) and I wouldn’t have to worry about a stall at the signal light. Replaced them with a set from a 74 CB750 and appreciate the difference.
Glad you got yours sorted out.
2002 Electra Glide
1978 750K
1966 CL77 (sold)
2020 CB500X
Offline Paintedseat
« Reply #2 on: March 29, 2018, 09:26:23 PM »
No warm up time needed. I choke to start choke for about 2 minutes choke off. Runs great from the get go.
Offline Erny
« Reply #3 on: March 30, 2018, 11:52:28 AM »
what do you mean by that? Any photo?
Sorry for the question, I plan to clean/rebuild carbs too (K7, PD41A)
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline Paintedseat
« Reply #4 on: March 30, 2018, 11:56:22 AM »
The metal rod that goes up to the top of the carb. There is a arm that pushes the rod downward when you twist the throttle. You want the arm to activate or start pushing the metal rod as soon as you start twisting the throttle. It should be touching or at least within a mm. You can bend the arm if needed. I don't have a picture I should have taken one.
« Reply #5 on: March 30, 2018, 12:05:46 PM »
On my 78K there was a good sized gap between the tab that actuates the plunger and the plunger rod. You simply bend the tab gently until it touches the plunger rod. This squirts some gas into the carbs instantly when you twist the throttle.
Very simple and gives you good response. I use the choke until I clear the stop sign at a bad intersection at the end of my street, push it in and ride it to do the warm up.
