Author Topic: Bill Benton, Mike Rieck, Jon Weeks.  (Read 2402 times)
  • Moderator
« on: March 30, 2018, 03:11:58 PM »
Hi guys, can anyone help this new member.
http://forums.sohc4.net/index.php?action=profile;u=51647
He has posted on the Automatic page and had no answers to his question.
Please check out his posts to see if you guys can help.
Regards Sam.
Offline calj737
  • I refuse...
Re: Bill Benton, Mike Rieck, Jon Weeks.
« Reply #1 on: March 30, 2018, 03:54:02 PM »
Offline dusterdude
« Reply #2 on: March 30, 2018, 03:58:01 PM »
You're so sweet
Sent from my R1 HD using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #3 on: March 30, 2018, 05:39:34 PM »
Jon cruises FakeBook more these days. Try there.
  • Moderator
« Reply #4 on: March 31, 2018, 02:22:32 AM »
Here's a copy and paste of the PM that he sent to me.
He lives in the UK but I'm not sure where.
I PM'd another forum member with this and he suggested I refer to you. This is the email. Can you help? If you can't, any ideas?
Hi there, I saw some of your posts and thought you may (please) be able to answer a question, as you seem to have had a transmission stripped down?
I have a 76 completely disassembled, with the intention of doing a full rebuild. When I stripped the transmission, I found the stop pin for the return spring on the kick start had been torn out of the casing. I tried to figure out how this could have happened and ended up with the idea that the device in the assembly on the mainshaft, which incorporates the input shaft for the torque converter, two cogs and what looks like a sprag clutch between the two gears.
The two gears are locked together, which doesn't make sense, as that would mean the kick start gear would be ratcheting all the time (the pawl IS very worn). It would also mean you can't turn the motor backwards, if the stop pin were refitted (after some welding).
I can't find anyone who has worked on one of these or has a part to compare. Can you help, or do you know who may be able to? I can send a photo or diagram of the part, if that would help.
Rod Mackay (Forum ID CB750A)
  • Moderator
« Reply #5 on: April 01, 2018, 10:35:28 AM »
Bump.  ;)
Offline POPS 911
« Reply #6 on: April 13, 2018, 04:55:55 PM »
If you live near Columbus,Ohio I have garage full of CB750A [ 1976-78] you can buy all or parts..... SPARES ARE NICE TO KEEP AROUND.
POPS BK911
  • Moderator
« Reply #7 on: April 14, 2018, 05:16:28 AM »
4000 miles is not really close to Ohio Pops.
Offline POPS 911
« Reply #8 on: April 16, 2018, 09:54:02 AM »
To bad I was going to give him for FREE two CB750A a 1976 and a 1978.
POPS BK911
  • Moderator
« Reply #9 on: April 16, 2018, 10:42:26 AM »
Not to worry Pop's, he hasn't been back to the forum since he asked for help.
I don't know the guy but he lives somewhere in the UK and after sending me a PM asking for help, he has never got back to me after I replied to him, but thanks for the offer anyway.
Sam.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #10 on: April 16, 2018, 11:35:15 AM »
POPS BK911
I'll take you up on that!  ;)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline POPS 911
« Reply #11 on: April 19, 2018, 04:12:53 PM »
WILBER: All the 750 SOHC I have are HONDAMATIC'S = Not broken motors and one head that has been open up and new seal and clean as a pin all valves cleaned and seats polished, no broken fins. One motor broken fins but ran fine [1976] frames and wheels but I have to keep tanks and side covers.
POPS BK911
