Author Topic: Accelerator pump fuel hose restrictors  (Read 1601 times)
Offline sammon287
« on: April 02, 2018, 06:55:10 AM »
  I'm rebuilding the carbs on by '76 750a (PD44A) and was reading through this thread http://forums.sohc4.net/index.php?topic=146893.0 . I did not realize the accelerator pump hoses between the carbs had restrictors in them and I discarded the hardened old hoses. I searched and can't find a source for these. I assume it's just a tiny brass tube that presses into the hose. Does anyone know a source for these parts? What will happen if I don't use them?
1976 CB750A
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Accelerator pump fuel hose restrictors
« Reply #1 on: April 02, 2018, 07:26:03 AM »
Dimensional data for the restrictor inserts and crossover tubing size can be found here:
http://forums.sohc4.net/index.php/topic,152294.msg1740385.html#msg1740385
You can buy a length of rigid tubing from McMaster Carr and cut your own:
https://www.mcmaster.com/#9811t17/=1c8kybi
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Paintedseat
« Reply #2 on: April 02, 2018, 07:32:25 AM »
I would assemble and test. I think they mainly reduce the amount of fuel volume in the system. Basically less mass for the tiny diaphragm to push. But you could try without and see what kind of stream you get. I think others have tried with success
Offline sammon287
« Reply #3 on: April 02, 2018, 07:53:36 AM »
Excellent info. Thank you. If I cut some from tubing, any idea how long they should be? Does it matter? If it's just a flow restrictor, I don't think it would matter, but if it's a volume reducer, I guess it could.
1976 CB750A
Offline sammon287
« Reply #4 on: April 02, 2018, 07:57:12 AM »
I actually ran it for awhile without them, but there were always compromises and I'm starting over from scratch. I can't say if the absence of restrictors affected the rideability issues. It's been so long since I rode this bike, I couldn't even describe the issues it had now.
1976 CB750A
« Reply #5 on: April 02, 2018, 08:43:20 AM »
I know it has been posted, but the site search is down but Google search works pretty good is you use the advanced Google search to limit the search to the SOHC/4 site
TAMTF...
Wilbur
Projects:
« Reply #6 on: April 02, 2018, 08:50:11 AM »
http://forums.sohc4.net/index.php/topic,109253.msg1525955.html#msg1525955
TAMTF...
Wilbur
Projects:
