Author Topic: 750: why so difficult to kick over  (Read 946 times)
Offline Henning
« on: April 02, 2018, 09:53:52 AM »
I'd like to think it's because I have masses of compression, but the engine is stock and with close to 50K miles on the clock, I don't think that's the case. Oil is 20W50 and it was cold in the garage, 3C / 37F, so obviously that wasn't helping. Also, the stop valve in the oil pump is buggered so all the oil drains to the sump. So is this just the oil dragging on the crank as I try to kickstart it or could there be something else binding. Bike runs well otherwise and revs happily. Thanks.
71 or thereabouts 750 K1 - this one should have been put down
Re: 750: why so difficult to kick over
« Reply #1 on: April 02, 2018, 10:55:56 AM »
 Sounds like a plausible explanation. How long had it been sitting since it was turned over last ? I know I don't move as well when its very cold  ;)  :D
Offline Henning
« Reply #2 on: April 02, 2018, 11:13:41 AM »
It last ran it in October, so it's been sitting all winter. I do turn it over once in a while with the kicker. It's been an issue the last few years, I'm posting as I don't recall any posts about this specific problem, even though the leaky stop valve is a well known problem.
Offline RandomOrbit
« Reply #3 on: April 02, 2018, 11:54:52 AM »
I notice a significant difference on cold mornings, down in the mid-30s F as compared even to mid 40s. I use 10w40, I expect 20w50 would be even more pronounced.
CB750k6 owned since 1991
« Reply #4 on: April 03, 2018, 09:31:55 PM »
Start and let it idle for a few minutes?
Oil pump that let oil flow to sump should not be any problem. My CB750 K6 had such pump the first 100.000 km. I replaced it 2 years ago with a pump that keep oil longer in tank.
« Last Edit: April 03, 2018, 09:34:10 PM by PeWe »
Offline 2wheels
« Reply #5 on: April 04, 2018, 11:51:02 AM »
remove the spark plugs and try.
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Offline Henning
« Reply #6 on: April 04, 2018, 12:27:56 PM »
The problem is getting it started in the first place :-) Battery is old and tired so it's kick only until I get round to buying a new one. But it's like kickstarting through thick treacle so question is what's causing that.
