Author Topic: Cracked side panel ?  (Read 2126 times)
Offline rddcw
« on: April 04, 2018, 08:20:10 AM »
Though the left side panel is on my Yamaha XS1100, but is has a vertical crack that is approximately 4" long from the bottom on the panel.
What are you guys using for your repairs ?
Thought about using some JB Weld Plastic Weld with maybe some fiberglass backing, Any thoughts about this ?
Offline Bankerdanny
  • Endeavor to persevere
Re: Cracked side panel ?
« Reply #1 on: April 04, 2018, 08:46:16 AM »
I use fiberglass on the back side. Then you can use filler to deal with the front side of the crack.
Offline slikwilli420
  • Master of Disaster
« Reply #2 on: April 04, 2018, 09:26:44 AM »
A lot of guys like the super glue and baking soda deal. I have never done it, but many rave about how long it has lasted.
« Reply #3 on: April 04, 2018, 09:31:43 AM »
Since it is not a CB spare part you might find a good one for not much money.
Offline rddcw
« Reply #4 on: April 04, 2018, 11:32:15 AM »
Side covers not broken are just as pricey as any other Vintage Bike !
    • http://forums.sohc4.net/index.php?PHPSESSID=qfmbtvv4knjm5ehffbfbb4p7g3&/topic,60973.0.html
« Reply #5 on: April 04, 2018, 11:57:11 AM »
the lego melding in acetone dont vork on Yamaha dt on/off road bikes..have no idea if it use same plastic un xs
..it have been real good to fix my Honda parts..
plastic is not just plastic...so the glue must be for the korrekt type
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #6 on: April 04, 2018, 02:21:04 PM »
The JB Weld plastic welder cement is the least effective of any of the products I have used. The best has been the Permatex version of plastic welder two part epoxy, followed by DURO and Devcon versions. The JB Weld type seems too slick to hold as well as the other brands, or something, but it isn't as good as the others. I like to groove the rear side of the crack with a rotary burr, and rough up the plastic back there with 80 grit paper, then mix and spread into the crack, allowing it to penetrate the crack by slightly spreading it, and then wiping the outer side of the crack to remove any excess there. If done properly, it won't break there ever again. You can reinforce it with some light fiberglass cloth, but I haven't found it necessary.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline nvr2old
« Reply #7 on: April 05, 2018, 09:55:53 PM »
I've had real good results using hardware store 2 part plastic epoxy in the same kind of dispenser in your picture.  Groove the crack out with a dremel on both sides, sand around the area with 80 grit, mix, apply, wait 30 minutes, sand with 80 grit on a block..good as new.  Solid fix.  Cheap.
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
Offline rddcw
« Reply #8 on: April 06, 2018, 07:41:21 AM »
Fixed it !
Used some ABS cement and 1" wide fiberglass drywall tape on the backside of the panel and holding up nicely. Applied the cement first carefully spreading the crack using an Acid brush to lay down the cement. Then laid my tape over the length of the crack covering the tape with the cement again.
Appreciate the "input" from all the Forum members !
