Now, I have been working on bikes for years, and have ran across some rims that are easy to remove, and some that take a bit more work. My Royal Enfield is pretty easy, with the sprocket staying on the swing arm, and the chain also.
I was reading up on removal of my rim on the CB750K1 I have, and both manuals say to just loosen the nut on the axle, but do not say to remove the axle, but to loosen the chain adjusters, and swing them down, and remove the rear wheel. This is after disconnecting the brake stay and rod. Is it possible to remove the rear wheel without pulling out the axle first, or the chain? I imagine that the axle would have to be removed eventually for brake shoe replacement, or tire replacement, but was curious as to the easiest way to get the rim off the swing arm? I was prepared to disconnect the stay, brake rod, remove the castle nut and cotter pin from axle, then withdraw the axle from the rear rim, and extract the rim from under the rear fender, after breaking the chain at the master link. Would this be the proper way to do this? Or, is there a more efficient way that I am not seeing...
Charlie
