Author Topic: tach mounting bracket  (Read 1063 times)
Offline aminemed
« on: April 09, 2018, 07:03:28 AM »
Guys
any creative idea on how to mount a cb 750 tach on this triple tree?
Offline slikwilli420
  • Master of Disaster
Re: tach mounting bracket
« Reply #1 on: April 09, 2018, 07:29:57 AM »
Have some bungs welded underneath that you can screw a bracket into. Could mount to the forks for something a bit different as well.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #2 on: April 09, 2018, 08:08:02 AM »
this is what i would do also.
or source another top tree to chop up, but keep the original clock bracket mounts.
--Evan
1975 CB750K "Rhonda"
Offline aminemed
« Reply #3 on: April 09, 2018, 09:06:26 AM »
i don't have any welding skill :( i'll need to look for a fork bracket then
« Reply #4 on: April 09, 2018, 09:35:13 AM »
Has to be a local fabrication shop that has welding capability. If you had it all set it shouldnt be more than $10 or so to weld them on.
« Reply #5 on: April 09, 2018, 10:05:13 AM »
 Drill it and countersink a pair of stainless steel button head bolts through it. Only if it's thick enough.
Offline jgger
« Reply #6 on: April 09, 2018, 06:42:38 PM »
Maybe get a set of double ended studs to replace the pinch bolts on the top tree.
« Reply #7 on: April 09, 2018, 08:03:42 PM »
How big a tach? On Duc singles they mounted to the side, held on by fork cap.
« Last Edit: April 09, 2018, 08:06:41 PM by 754 »
Offline aminemed
« Reply #8 on: April 10, 2018, 02:21:36 AM »
It's the CB 750 Tach, so quite big :)
« Reply #9 on: April 10, 2018, 02:43:40 AM »
The upper bolts can be longer and hold a bracket too.
Offline aminemed
« Reply #10 on: April 10, 2018, 02:59:31 AM »
this is the idea i'm going to follow..i'll make a bracket that would hold the original tach in between the two bolts
