Author Topic: Having electrical ignition issues??  (Read 1414 times)
Offline neurotoxin312
« on: April 11, 2018, 07:18:53 PM »
I just replaced the wiring harness on my 76 CB550 and unfortunately, I'm having ignition issues.
What is the best way to test if my ignition switch works? I never had a stock ignition switch and my previous wiring harness was so chopped up so I couldn't rely on how it was set up previously. I took the time to check out the wiring diagram and it seems like black & black red tracer wire?
I would also like to bypass my ignition switch if. Any ideas on that?
Offline calj737
  • I refuse...
Re: Having electrical ignition issues??
« Reply #1 on: April 11, 2018, 07:58:40 PM »
Is the KILL switch set to RUN? Do you have 12v at the coils (BLK/WHT wire)? If yes, then the ignition switch is fine.
Is it turning over, but not firing? You may have a harness that depends upon the Clutch Safety Switch. So, pull the clutch lever and try again.
And please provide some specific detail as to what is happening (or not)  :)
« Reply #2 on: April 11, 2018, 08:34:09 PM »
Ahh yes! Good idea with the clutch safety switch. It will need to be bypassed. I didn't do that. I will check the black and white wire. Is that the dual bullet connector for the ignition coils?
Offline Deltarider
« Reply #3 on: April 11, 2018, 11:30:35 PM »
Yes.
CB500K2-ED Excel black
« Reply #4 on: April 12, 2018, 03:58:55 AM »
Which wires do I need to bypass in the headlight bucket for the clutch switch? Would it be the green red Tracer wire connected to the solid green?
Offline calj737
  • I refuse...
« Reply #5 on: April 12, 2018, 04:40:29 AM »
See right here:
« Reply #6 on: April 13, 2018, 06:42:39 AM »
Ok great! I got her working again! Thanks for that tidbit!
My second question now involves the taillight activation. There is a brown wire that serves as the drive light for the tailight (not the brakelight Green/yellow tracer wire).I traced the brown wire on the wiring diagram and it seems like there is a female bullet connector that is left unconnected in the headlight bucket. It also seems as though the brown wire is connected to a brown/red tracer wire at some point?
My question is when does this brown wire activate? When I tested, I cannot seem to get 12v across this wire unless I go past the "Ignition" on my ignition switch (the 2nd click). Essentially, I cannot turn on my tailight, but I can turn on my headlight.
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #7 on: April 13, 2018, 06:53:18 AM »
You need a jumper wire to the Brown bullet connector, if it is a double or triple female, then you need a male bullet feeding it from a switched 12v source, maybe a black wire. If it is a male bullet, find the triple female, and plug it into the back of it. That connection is often overlooked.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline Deltarider
« Reply #8 on: April 13, 2018, 08:25:41 AM »
Other markets than the US had a separate position light (Ba9s, 5 Watts) in the headlight reflector. That's what the brown wire is for. These markets had an extra P position at the lightswitch. That same bulb is ON with the taillight when ignition key is switched to 'P'. Honda didn't bother to make an extra wire harness for the US market. That's why you have that unconnected brown wire in the headlight.
« Last Edit: April 13, 2018, 08:28:37 AM by Deltarider »
« Reply #9 on: April 13, 2018, 10:22:58 AM »
Charlie
When I connected that brown wire to a black switched hot wire, I burned out a fuse lol.
Offline calj737
  • I refuse...
« Reply #10 on: April 13, 2018, 05:34:36 PM »
This is a 550, not a 750. The BROWN wire is activated wire the key. RED is always hot, RED WITH KEY activated black, BROWN, and BRW/WHT thru the fuse block.
The TAIL is a separate fuse for the BROWN. Do NOT connect BLACK to BROWN.
Offline Yamahawk
« Reply #11 on: April 14, 2018, 06:15:16 AM »
My bad, yep I was thinking CB750, not 550... sorry!
Charlie
Edmund Burke
Romans 8:28
Job 13:15
