Hey All,
Just doing routine maintence and I decided to adjust my Cam chain tension on my 350f.
I was finicking around and loosened the actual bolt all the way out. What ever tension I had set was then completely loosened... ever since I did that the bike will not start.
It will lug and I’m pretty sure that’s because the tension is super loose but what I am afraid That happened is that it got so loose that the chain went off the sprocket and is now just on the bar. Has this ever happened to anyone else ?
now I’m having to put pressure on the spring and then tighten the bolt but I haven’t had any success yet getting it started.
Pretty upsetting, maybe I just haven’t put enough pressure and tightened right?
