Author Topic: Please help.. I hope this didn’t happen  (Read 1968 times)
Offline Dos
  • Owner of a cb350f
« on: April 14, 2018, 04:34:28 PM »
Hey All,
Just doing routine maintence and I decided to adjust my Cam chain tension on my 350f.
I was finicking around and loosened the actual bolt all the way out. What ever tension I had set was then completely loosened... ever since I did that the bike will not start.
It will lug and I’m pretty sure that’s because the tension is super loose but what I am afraid That happened is that it got so loose that the chain went off the sprocket and is now just on the bar. Has this ever happened to anyone else ?
now I’m having to put pressure on the spring and then tighten the bolt but I haven’t had any success yet getting it started.
Pretty upsetting, maybe I just haven’t put enough pressure and tightened right?
Offline Dos
  • Owner of a cb350f
Re: Please help.. I hope this didn’t happen
« Reply #1 on: April 14, 2018, 05:19:55 PM »
Can the chain not come off the sprocket and I’m just freaking out?
Offline Gene
  • Chat enuf you too can be a
« Reply #2 on: April 14, 2018, 05:26:55 PM »
It is possible it jumped off the sprocket, I would imagine it would be making an credible noise or freezing up tho.
Just take off the tensioner and put it back together, re-set. If that doesn't work you'll need to pull the cam cover and see.
Don't panic.
*1973 CB750K3 (Bow)
Offline Dos
  • Owner of a cb350f
« Reply #3 on: April 14, 2018, 05:47:51 PM »
I keep on picking and picking with the bike and creating a problem when there isn’t  :-\
I’ve got a video shoot with it tomorrow and if I don’t fix it before I’m screwed lol.
I’m going to remove that little piece of the frame to get more leverage. It isn’t grinding or anything just super loose.. I’m pretty sure I can hear the loose chain.
Offline Dos
  • Owner of a cb350f
« Reply #4 on: April 14, 2018, 05:49:02 PM »
Don't panic.
When you mean take off the tensioner that’s just loosening it and re applying pressure and tightening right?
Offline markreimer
« Reply #5 on: April 14, 2018, 10:18:15 PM »
If you’re not sure the cam chain is on, just remove a valve adjustment cap and see if the rockers move when you kick the engine over. No cam chain = no top end movement.
Offline Dos
  • Owner of a cb350f
« Reply #6 on: April 15, 2018, 08:37:34 AM »
Got it!
Freaked out alittle bit.
Does that sound alright to you?
Offline Coredozer19
« Reply #7 on: April 15, 2018, 10:20:30 AM »
If that video is considered normal than I’m good because mine is super quiet but I’m still a little nervous about hearing the cam chain. Fresh rebuild.
1973 Honda CB350F
Offline Flyin900
« Reply #8 on: April 15, 2018, 10:26:24 AM »
That's good.  8)
Leave the poor thing alone now!  ;)
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline Dos
  • Owner of a cb350f
« Reply #9 on: April 15, 2018, 10:39:39 AM »
I do feel like it can be quiter..lol this ocd.
Offline Dos
  • Owner of a cb350f
« Reply #10 on: April 15, 2018, 10:40:03 AM »
I should do a fresh rebuild haha?
« Reply #11 on: April 15, 2018, 01:04:14 PM »
This on 750s and maybe yours, if you loosen the bolt, even pull it right out....... that does not mean the tensioner will move.. it may or may not.
