I run a 2.5 front and 3.0 rear on my race bike with 110 and 130 tires. 2.5 is too skinny for a 130 tire in my opinion and many tire manufacturers would agree. The 18s front and rear in those widths expands tire options and gives it a great look with solid handling.
I have to correct myself as memory got the better of me. I currently have the same set up Matt has listed here. It has worked very well for about 25 years.
I can't help to enter this question too.
- 110/80-18 front will fit a K2-K6 fork, stock fender?
(100/90-19 used with no issues)
Tire has not much air when mounting the wheel, right?
130/80-18 rear has been used before on my bike. Maybe I had to massage the stock chain guard a little.
- Will 130/80-18 on 3" rim have wider tire area against the road than stock?
I have understood here that these tires + rims should work.
My rear tire disappear very quick
120/90-18 on 2.15" rim flattened out at around 4000km with snake handling in light corners. 4.0-18 better.
One tire got bad handling after only 3500km.
Racers have opposite "problems" when tire sides wear faster then center, right?
The fatter tire on a wider rim will be better?
130 rear need a matching front so 110 there for ok handling in corners, right?
I have a front hub, time for another rear hub , rims and spokes for an extra setup of wheels if doing this.
