Author Topic: Battery question 73 CB 350F  (Read 595 times)
Offline Badger
« on: April 25, 2018, 07:09:22 AM »
Greetings Comrades!
OK so Badger had a senior moment today.  The question for you.  In the pic you see +/- for battery plus that third one with the round connector.  Where does that one connect?  I removed the battery box a couple months back and just don't remember.
Thanks for helping out an OLD dude...
1973 CB 350 Four
2014 Harley Davidson Electra Glide Limited with the wethead
Offline Flyin900
Re: Battery question 73 CB 350F
« Reply #1 on: April 25, 2018, 01:11:55 PM »
If it is a green wire underneath that black cover then it is the ground connector that attaches to the top front bolt that secures the battery box to the frame. Unless someone has covered the wire sheath it should be a green ground wire unless you have one already off the main harness connected to the ground on the battery box.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline Badger
« Reply #2 on: April 25, 2018, 05:43:16 PM »
Thanks a lot for enlightening me, it is appreciated.  Once my carb bank gets back from Oldskool carbs I should have it up and running in short order
1973 CB 350 Four
