Author Topic: Bought some turn signals off Amazon... and they melted  (Read 696 times)
Offline BARKER
  • Nova Scotia, Canada
    • Check out my YouTube Channel!
« on: April 25, 2018, 02:14:27 PM »
Like the title says... I bought some front and rear turn signals off Amazon... and the wiring completely melted. Scariest thing to ever happen in my shop (and to my 1974 CB750K). I plugged my factory Honda stuff back in and it all worked perfectly (of course  ;D ).
Turn signals - https://www.amazon.ca/gp/product/B01FF8YIVS/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Electrical specs on the website (I'm guessing this is my problem somehow)
Voltage: DC 12V
Wattage:10w x4
Please tell me oh wise Honda folks... did I screw this up based on the wattage? Or did I simply get what I paid for? I realized after ordering them that the fronts should be dual filament.
My YouTube Channel (contains CB750 stuff!)
-1974 CB750K Project
-1987 Toyota AE86
Offline BARKER
Re: Bought some turn signals off Amazon... and they melted
« Reply #1 on: April 25, 2018, 02:37:58 PM »
I definitely wired the fronts up completely wrong now that I'm looking at them.
Where they aren't dual filament, I had both wires hooked to the running light and blinker. No ground.  :-[
Although... I don't know why the rears didn't function. One melted and the other just stays dimly lit, steady on and won't blink.
-1987 Toyota AE86
Offline BARKER
« Reply #2 on: April 25, 2018, 07:15:15 PM »
So I have everything back together. Where these are two wired I only have the blinker wired, no running lights up front.
So now when I activate the signal to the left or right position the signals come on brightly for a moment and then hang half lit. Almost as if the flasher relay can't fully disengage. What could cause this?
Mechanical I can do... Wiring... Not my strong suit.
-1987 Toyota AE86
« Reply #3 on: April 25, 2018, 09:19:43 PM »
 I'd try a new blinker and double check for grounds.
Offline RJ CB450
« Reply #4 on: April 26, 2018, 09:21:53 AM »
"4 x turn signal lights (Sensor Load Resistor Required, Not Included with the Package) "
Are these an LED bulb? Or more likely, a much smaller bulb vs the original 1156 bulb.  Standard relay requires load to function properly.  Also, if you only have single indicator on instruments, I am guessing it flicks both sides?
« Last Edit: April 26, 2018, 09:23:26 AM by RJ CB450 »
74 CB450 K7 Supersport, 82 CB650sc Nighthawk, 1982 CBX 1000, 2015 Tiger XCx.... And some ol minibike with a 5hp Briggs.
