Author Topic: gas leaking from carb T junction  (Read 1016 times)
Offline aminemed
« on: May 01, 2018, 05:51:34 AM »
hi all
i had to work on my carbs lately and i had to separate carb 4 and 3. Since then, i have a strong leak from the T junction between those 2 carbs. I took off my carbs 3 times since the leak to figure out where it is coming from first then to check the o rings. These seem to be still in a good shape. What else can i do to stop this leak? It is even more leaking when i ride the bike in the streets (dont want to catch fire etc..)
it is a 750 with 657b carbs
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: gas leaking from carb T junction
« Reply #1 on: May 01, 2018, 07:11:42 AM »
replace the o-rings.  some may disagree but i took mine down to the auto parts store and found some that fit.  haven't leaked since.
cb750 k6 - ugly
Offline aminemed
« Reply #2 on: May 01, 2018, 08:19:59 AM »
thank you
to be able to ride before buying new orings i put some jb weld around the t junction, dont know if it will be fuel resistant.
Offline Coredozer19
« Reply #3 on: May 01, 2018, 09:40:49 AM »
dont put jb weld on that junction or you will never be able to get it apart, I highly do not recommend doing that,
1973 Honda CB350F
Offline aminemed
« Reply #4 on: May 01, 2018, 10:17:12 AM »
thx what about polyester filler ?
« Reply #5 on: May 01, 2018, 11:33:28 AM »
New o rings are the correct fix. Goop will just make a worse mess. 2x8mm or as close as you can get.
« Reply #6 on: May 01, 2018, 01:38:05 PM »
2x8 work well for me also. Bought a whole bag  on E-bay for a few bucks. Somebody will curse you someday using JB Weld in that spot  ;)
Offline aminemed
« Reply #7 on: May 01, 2018, 02:18:31 PM »
ill get the new orings tomorrow thank you a lot
