Checklist for test flight completed.
1. carbs(or is that crabs?) cleaned and remounted
2. brakes disassembled, cleaned and inspected. In the past I made the mistake of test riding a Silverwing without attending to the front brake, which decided to seize and start smoking more than an old worn out 2-stroke. Also made the mistake of not inspecting the rear brake on a bike, of course it decided to delaminate and lock up the rear wheel. Fortunately for me I was doing less than 20, did not fall nor get hurt.
3. tires inflated. These tires are not safe for anything other than a test ride. Story to follow at 11, well..............maybe waaaay later
4. chain adjusted, inspected and lubed
5. same with cables, especially throttle- long time ago I had a throttle cable stick WFO.
6. oil changed and filter looked at(it'll be replaced when bike is given the green light for further repair).
7. air filter inspected
8. tank and petcock inspected and cleaned if necessary
9. valves and timing, especially important on our sohc not so much as of now on an electronic ignition, shim valve adjusted bike
10. all lights working and system charging, which this does.
11. compression tested, first thing done. I'm working on a 750 K7 that had less than 50 psi per cylinder, after a dose of Kroil it came up to 100 and eventually rose to normal after running. BTW, never was nor have been a fan of the K7 and 8 style but they sure to run well.
So I decide to hook up the remote mini bike tank and sync the carbs with one of my Morgan Carbtunes( for some reason I have two sets). Go to hit the starter and Mr. KZ dies. It had started every time until then, acted as though there was either a large draw or bad connection(lights on, hit starter and everything dies). So I check and recheck all cable connections, starter and solenoid too. Same death upon start. Sooooo, I pull the battery and take it to Mark, who gave me the bike, to load test. Wound up it had decided to give up the ghost. He has a battery load tester, that may be a tool I need to acquire. I spent a bunch of time troubleshooting not thinking of the battery as it had started the bike several times.
So I bring the battery back and had to jump the bike using a car battery. No vacuum on cylinder 4. Huh. That was an easy fix-the tube in the Morgan was sticky. Sync 1 to 2, 3 to 4 and both banks together. Ready to ride when the new battery arrives. I was able to find an AGM for less than 60 with free shipping. So, I am up to an 80$ expense ledger
IMG_9365[1] by
Lawrence Moulder, on Flickr
