Author Topic: Headlight and starter button not working  (Read 500 times)
Offline devin92
« on: August 12, 2018, 02:41:45 PM »
The headlight and starter button stopped working right when i was loading it up for a safety. I had just started it, then shut it off with the key, turned the key back on and no headlight, and no starter button working. I've checked the headlight wires, killswitch wires, battery, all fuses and even the starter button, but nothing has worked.
Re: Headlight and starter button not working
« Reply #1 on: August 12, 2018, 04:03:39 PM »
What bike?
Offline devin92
« Reply #2 on: August 12, 2018, 04:36:30 PM »
1980 cb650.
Offline kerryb
  • Not a very
« Reply #3 on: August 14, 2018, 07:02:29 AM »
Have you ckecked the ignition switch?  Make sure power is getting to and through it.
Offline jakec
« Reply #4 on: August 14, 2018, 01:55:19 PM »
I went through this with my bike, if your wiring is similar then your headlight current is running through the starter switch. So if the switch breaks the headlight stops working.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
