Author Topic: snapped engine bolt  (Read 1510 times)
DAVE H
snapped engine bolt
« on: January 09, 2007, 09:23:43 AM »
Hi when removing the engine crash bars on my f2 the front left hand engine bolt snapped off.the remaining part of the bolt and nut remaining in the engine lug,tried tapping it out but is well solid,would it be ok to apply some heat to remove it,or has anybody any other solutions thanks.
DAVE H
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: snapped engine bolt
« Reply #1 on: January 09, 2007, 09:31:33 AM »
Heat is a good start. Also soaking with a good penetrant. Good luck with that!
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline spitfire
« Reply #2 on: January 09, 2007, 10:00:25 AM »
Hi Dave,
             The key thing is to remember DO NO DAMAGE, if it was mine I would clean up the area as much as possible, depends were the bolt is trapped/snapped, in the frame or on the engine, you don't want to damage either.
The nut is a captive one, held in place by the crankcase, clean that area as much as you can, then give it a good soaking with WD40, try tapping the broken end of the bolt, gently just to try and jar it loose, not a full on get out of here bash.
If that does not work, try heat and tapping, if that does not work it sounds like you will have to drill it out, very carefully.
Don't rush spend a few days on each attempt, but as I said earlier clean up that area as much as possible.
Cheers
Den
Wirral UK
1976 CB750F1 bought new in 76
1977 CB750F2: Restoration started
1964 BSA A65R: Waiting restoration
My gallery is here: http://www.sohc4.us/gallery/v/members/personal/spitfire/?g2_navId=x5a30f7b6
Offline silver fox
« Reply #3 on: January 09, 2007, 10:01:51 AM »
I had a similar problem on my BM R1150GS, soaked it for days to no avail, used heat, but to no avail, eventually had to drill it going from a pilot hole upto the point where i was at a drill bit just less than the bolt. Soaked it some more and then using a drift, hammered it out. Once out i didnt think it looked so bad as to be such a pain in the arris, Just dont go at it too hard or hot as you will end up snapping the lug!!!!
Good luck
Offline nippon
    • Classic Cycle City
« Reply #4 on: January 09, 2007, 11:49:34 AM »
Hello,
don't worry.
As last solution, you can remove the broken bolt by "spark eroding".
For an explanation please take a look at http://www.sparkeroding.co.uk/
I did it it with a broken engine bolt like shown at the pic. I was not able to remove the broken bolt with heat,
so I took the engine to a shop. The guy removed the bold by spark eroding.
Absolutely no damages on the thread, no need for helicoiling.
The bad thing was, i have paid EUR 40.00 because it was a slow and long lasting process.
In my case three hours to erode the bolt.
But much more cheaper than purchasing a case.
I have tested the thread with my torque wrench when I have replaced my bearings,...I'm absolutely satisfied with the result.
Good luck!
nippon
« Last Edit: January 09, 2007, 12:05:42 PM by nippon »
DAVE H
« Reply #5 on: January 09, 2007, 02:21:00 PM »
Thanks
for the replies guys,will proceed to the garage, armed with a coffee,and try your suggestions,closely folowed with a couple of beers if it does not come out. The broken part of the bolt is on the engine,will let you know how i get on.
Dave.
