Author Topic: Turn signal question  (Read 859 times)
Offline Coredozer19
« on: May 16, 2018, 06:22:53 PM »
1973 Honda CB350F. I got 4 new indicators. The ones I got have 3 wires. And the old ones only have two. Could I run a wire from the low beam feed to the front signals and run a wire from the brake running  light feed to make these running indicators operational?
Biggest question is. When the high beam is turned on does the low beam stop recieving voltage.
And when the brake is applied does the running light feed to the brake light stop or does it still receive voltage
1973 Honda CB350F
Offline spotty
Re: Turn signal question
« Reply #1 on: May 16, 2018, 07:15:00 PM »
yes, high beam will turn off low beam
tail light will still run with brake light operating
i blame Terry
Offline Coredozer19
« Reply #2 on: May 16, 2018, 07:30:55 PM »
Okay so I should run all my running indicators off of the tail light.
1973 Honda CB350F
Offline Mantree
« Reply #3 on: May 16, 2018, 08:14:26 PM »
Are they amber or red?  You can't have amber runing lights on the rear of the vehical.
Sent from my SM-G930V using Tapatalk
