Author Topic: Switching relays please read  (Read 674 times)
Offline Coredozer19
« on: May 19, 2018, 02:03:21 PM »
1973 Honda CB350F So I had this genius idea. I want my turn signals to be running lights as well as indicators. So what if I switched out the stock relay (normally open) with a new relay (normally closed) the lights would stay on all the time and when the signal voltage is applied to the new relay (normally closed) it will open and in turn make the indicators blink. Am I barking up the wrong tree?
1973 Honda CB350F
Offline piefairy
Re: Switching relays please read
« Reply #1 on: May 19, 2018, 04:21:48 PM »
If I am correct, the runs off a timing relay, not a basic relay. You would either need to find a blinker relay that is NC or you would need to add a relay and modify the wiring a bit for it to work.
You would want to take the POS in from the timing relay, splice it, and connect it to the common on NC connection opposite the common. The common would then run to the blinkers. The output from the timing relay would run to the POS leg of the relay coil.
I am doing this in my head, so I may be off a bit, feel free to correct.
Offline tlbranth
« Reply #2 on: May 19, 2018, 05:32:43 PM »
If you can point me to a wiring diagram of your bike I'll send you a way do do what you're trying to accomplish
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Coredozer19
« Reply #3 on: May 19, 2018, 07:13:16 PM »
I will take pictures and post on this thread directly from the book. I know it’s doable I’m just trying to go about it the cleanest way
1973 Honda CB350F
« Reply #4 on: May 19, 2018, 07:20:41 PM »
Just use the coils in place of the present lamps, and tie the lamps to the relay contacts with Brn/Wht supplying the power for the lights thru the contacts. I used to do this with the rear brake and turn lamps back there, changing the lenses to red to make more rear brake lights show up.
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #5 on: May 20, 2018, 10:17:18 AM »
Running lights are usually not as bright as turn signals.  Bright running lights might cause your battery to drain since the CB350 charging system is not real keen on heavy electrical load.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
