Author Topic: Transmission slip or clunk  (Read 1291 times)
Offline Coredozer19
« on: May 21, 2018, 09:47:33 PM »
When I let the clutch out a little hard I feel a grabbing popping clunking feeling. I can only describe it as it feels like the drive chain is slipping on the sprockets. 1973 cb350f  I didn’t replace clutch plates. Any ideas? It feels really unatural.
1973 Honda CB350F
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: Transmission slip or clunk
« Reply #1 on: May 22, 2018, 08:23:43 AM »
It could be a sign of something loose within the clutch assembly, warn shifting forks or engagement lugs on the transmission gears.  I've never heard of the primary chain slipping as it is a HIVO type.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Coredozer19
« Reply #2 on: May 22, 2018, 08:41:23 AM »
The bike has 5k mikes on it. Nothing appears to be worn in the transmission.
1973 Honda CB350F
« Reply #3 on: May 22, 2018, 09:55:22 AM »
does it happen in all gears or just certain one/s?
Offline Coredozer19
« Reply #4 on: May 22, 2018, 11:37:45 AM »
All gears. Forgot to mention that the bike has sat for 38 years. Original clutch pack from 73 could slipping clutches cause this
1973 Honda CB350F
« Reply #5 on: May 22, 2018, 11:42:00 AM »
Probably the clutch then...specifically what I don't know
Offline Coredozer19
« Reply #6 on: May 24, 2018, 08:40:36 PM »
Update. It only does it as you release the clutch. It does not do it when you engine brake and then hit the gas again.
1973 Honda CB350F
Offline CBJoe
« Reply #7 on: May 24, 2018, 09:16:18 PM »
Checked Drive Chain for excessive free play? Maybe that and a combination of hardened rear crush drive dampers
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline pjlogue
« Reply #8 on: May 25, 2018, 01:50:57 AM »
Check your drive chain for frozen/binding links and make sure it is adjusted and oiled properly then check your clutch for warped plates or glazing and check your clutch springs for sag. It is unlikely to be a primary chain issue.
-P.
Offline Coredozer19
« Reply #9 on: May 25, 2018, 04:39:08 PM »
Drive chain to the rear wheel is brand new. And tightened properly. If you let the clutch out real nice when shifting it doesn’t do it
1973 Honda CB350F
Offline kslrr
« Reply #10 on: May 25, 2018, 08:15:11 PM »
Have you physically inspected the clutch yet?
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
Offline Coredozer19
« Reply #11 on: May 26, 2018, 04:38:30 PM »
No. But what am I looking for when I do?
1973 Honda CB350F
Offline kslrr
« Reply #12 on: May 27, 2018, 07:33:57 AM »
Loose bolts, cracked basket, clutch springs of different lengths or bent, Bent steel plates, cracked fiber plates, etc.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
Offline Patrick
« Reply #13 on: May 27, 2018, 08:38:53 AM »
If the clutch only slips when you fist put it in gear, and then does not slip when you gun it after you are already in gear, I, personally would look first at my clutch cable. If it is the original cable and it is a little sluggish engaging, that could be your problem. Pull it off and check to see if the cable moves freely and easily in the sleeve. That will produce those symptoms.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
« Reply #14 on: May 27, 2018, 09:59:20 AM »
My CB750 front sprocket with chain can cause a clunk sound when taking off, especially when turning left at the same time. Sprocket can move sideways as designed to align with rear.
If engine stutter or hesitate due to too rich or lean at low rpm it will sound worse. My bike was like that end of last season and beginning of this. Hondaman clutch mod with extra holes drilled reduced that. I have stock clutch since last year due to more cc and need of all grip it can get
