I tried using that diagram with little success here. Could you help me out? I'm in much worse shape. Like an idiot I unplugged everything without taking pics first.
The left control harness is pretty easy it's the ground wires that are throwing me into a tail spin.
These I did not unplug I assume they are correct?
The long black wires at the bottom are from the front turn signals. I think i remember them plugging into the dual female orange wires?
Right behind that light blue wire there's a single orange wire with a double female connetor with a cover that is half white I assume one solid orange and one orange with a white stripe goes in there?
Here's where all the trouble started. which green wires go here? I have two from the headlight bucket. One for the tack light and speedo and a couple of others.
