SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Intermittently smoking
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Intermittently smoking (Read 1087 times)
Coredozer19
Enthusiast
on:
May 23, 2018, 07:12:02 PM »
Started it up (cold start) it’s smoking out of the left banks. I warm it up. Drive it and it stops smoking. Drive it a few more miles down the road and it starts smoking again from both pipes. Fresh rebuild. What is wrong with my bike? 1973 Honda CB350F.
Logged
1973 Honda CB350F
eigenvector
Master
Member of the despondent public
Re: Intermittently smoking
Reply #1 on:
May 23, 2018, 07:50:00 PM »
Cold start smoke
can
be oil leaking past the valve guides.
Did your fresh rebuild include new valve guides, if not that's what I would suspect. Personally unless compression was low smoke on a cold start doesn't bother me. If they were new valve guides I'd be bothered though.
As for it coming back - you didn't indicate whether or not you shut off the bike before that second leg of your trip.
Logged
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
ekpent
Really Old Timer ...
To many bikes-but lookin' for more
Reply #2 on:
May 23, 2018, 09:36:07 PM »
Could be that the second wave of smoke comes on when the pipes get hot enough to start burning off some oil.
Logged
dave500
WHAT?no gravy?
Reply #3 on:
May 24, 2018, 01:13:37 AM »
seems to be a few posts of fresh built 350/400s smoking?
Logged
Coredozer19
Enthusiast
Reply #4 on:
May 24, 2018, 06:06:28 AM »
Yes I am having a handful of problems. I’m getting frustrated. I did not replace the valve guides and the motor was sitting for 38 years untouched
Logged
1973 Honda CB350F
Coredozer19
Enthusiast
Reply #5 on:
May 24, 2018, 06:19:05 AM »
I know the first go around I put the oil scrapers in backwards so the engine was burning oil pretty good. So the pipes are coated I’m sure. I put a brand new set of plugs in it when I got it legal. Maybe 60 miles on them now. Hopefully they are clean. If not I’ll do a compression test and see what I get. If that checks out good then it is the valve seals right?
I also have red gasoline. The tank liner is red and it seems to be leeching into the gas. I dont know if that would cause it to smoke.
Also I noticed like I said after I let it sit on the side stand all day when I got back to the shop to ride home it was smoking from the left bank. Which could be because the oil stays up in the valve train on only that side if the bike is leaned. The other bank would have leaked back down into case due to it leaning right?
I just want to figure out what’s wrong. I’m tired of these smoke problems. I just want to ride it :,(
Logged
1973 Honda CB350F
Coredozer19
Enthusiast
Reply #6 on:
May 24, 2018, 10:48:28 AM »
What’s the CI kit? And I didn’t replace the valve guides
Logged
1973 Honda CB350F
danyo
Hot Shot
Reply #7 on:
May 24, 2018, 10:51:26 AM »
CI kit - pistons and rings from japanese seller on ebay - cruzinimage.
Sent from my SM-N900T using Tapatalk
Logged
eigenvector
Master
Reply #8 on:
May 24, 2018, 05:22:36 PM »
Worn valve guides are why it's smoking on start up (probably). Normal for an engine that old and unless it's excessive not really a big deal - what's excessive? Beats me - the local refinery points to you as to why there's so much pollution in the air?
Logged
Rob
1977 CB550K
1983 VF750S Sabre
Coredozer19
Enthusiast
Reply #9 on:
May 25, 2018, 04:41:57 PM »
Okay so I’ve decided that I’m not messing around at all anymore. I am going to put a brand new ring kit in it and new valve seals.
Can anyone point me to the right direction of a good kit for a top end job. I don’t care about money.
I need a head gasket and a lower jug gasket. And I need the valve seals.
Anything else anyone can think of that could be causing the oil in my cylinders?
Logged
1973 Honda CB350F
Coredozer19
Enthusiast
Reply #10 on:
May 25, 2018, 07:54:02 PM »
Are the valve guides not the silicone rubbers that come in the rebuild kit. The bike only has 5k miles on it. So if it’s a wearable item I doubt it’s worn.
Logged
1973 Honda CB350F
dave500
WHAT?no gravy?
Reply #11 on:
May 26, 2018, 01:12:10 AM »
they look like this,if the guides are worn new seals might hold for a while but will get distorted as the valve stem cranks over,old seals go hard and fail to flex to help seal,if they are the stock ones they'll be hard.
Logged
dave500
WHAT?no gravy?
Reply #12 on:
May 26, 2018, 03:53:03 AM »
worn guides WILL cause oil use and smoking,you need to find an engine rebuilder/machinist who gives a #$%*,these are a small engine and need attention to detail,they cant be slap happy.
Logged
Coredozer19
Enthusiast
Reply #13 on:
May 26, 2018, 07:28:29 PM »
Only the left bank smokes on startup and then once it warms up both smoke when I bang the throttle. Could this all be because of the valve seals. Or could I have a ring bore issue aswell?
Logged
1973 Honda CB350F
Deltarider
I'm back
Reply #14 on:
May 27, 2018, 12:13:19 AM »
You could try an oil that makes the rubbers swell a bit more and supple, like Castrol's High Mileage.
Logged
CB500K2-ED
Excel black
Coredozer19
Enthusiast
Reply #15 on:
May 27, 2018, 06:47:02 PM »
I’m just gunna pull it apart and replace the piston rings and the silicone seals.
Where should I get new rings from. I want something reliable.
Where should I get the seals from?
Logged
1973 Honda CB350F
Coredozer19
Enthusiast
Reply #16 on:
May 28, 2018, 05:23:23 PM »
Confirmed. I can see the oil coated on the intake valve where it shouldn’t be.
Logged
1973 Honda CB350F
dave500
WHAT?no gravy?
Reply #17 on:
May 29, 2018, 12:52:39 AM »
have a look at the guide and valve stem wear aswell.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
