Author Topic: Wrong axle &/or wrong swingarm..or brake backing plate?  (Read 7348 times)
Re: Wrong axle &/or wrong swingarm..or brake backing plate?
« Reply #75 on: July 30, 2018, 11:58:09 AM »
Could be the swingarm, easy to straighten.  If it's too far too chain side I suspect bent.
Will add more Info later.
Offline BPellerine
« Reply #76 on: July 30, 2018, 07:17:15 PM »
OK so you guys were right about the DOHC hub!!  I have the correct backing plate (thanks Frank!) and the whole wheel and spacers fit perfectly with a free spinning brake!
I was about to celebrate and then noticed the chain line  ::)  It doesn't look good to me. Comments?
dont know what year the frame is,but if you have a k7/k8 swingarm on a pre k7 frame it will throw the chain line out,as the k7/k8 arm is 10mm wider on the drive side,can not tell if your shock is vertical when viewed from the rear,just something to check.billp
1978 CB 750K ard and webers
another anfob
Offline Johnny340
« Reply #77 on: August 06, 2018, 09:14:30 AM »
Neither shock is vertical...they both splay outward at the top?? The frame is a K2 and the swingarm could be any year I'm starting to think..  If I move the wheel over about 8mm, the chain will line up and the wheel should be more centered as well so I'll try that next I guess.
1975 CB750F0 Super Sport
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #78 on: August 06, 2018, 09:45:02 AM »
Innthe pic of your sprocket on page 3, the lower mount is 180 degrees out, maybe for clearance ? To chain.  You can the flanges piece off the sprocket.
 Can you stand bike up straight and get avrear shot ?
Offline Johnny340
« Reply #79 on: August 06, 2018, 12:16:01 PM »
Are you referring to the lower shock mount Frank? They are Koni shocks and the bolts thread in from the outside which looks correct.
I don't have the wheel on now but here are a couple more pics. Thx.
Sent from my SM-G930W8 using Tapatalk
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline Johnny340
« Reply #80 on: August 06, 2018, 01:37:38 PM »
More pics. I'm starting to think it's not that far off as it is.  5mm right might be better but necessary? Comments welcome!
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline BPellerine
« Reply #81 on: August 06, 2018, 01:59:59 PM »
the lh shock is splayed out the most,looking at your pic,thinking the swingarm is wrong,too bad you did not have a known pre k7 to compare.bill
another anfob
Offline Johnny340
« Reply #82 on: August 06, 2018, 03:38:28 PM »
Does the K7 have this kind of chain guard mounting pattern?
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #83 on: August 06, 2018, 04:38:46 PM »
That is a k 6 or older swingarm.
« Last Edit: August 06, 2018, 07:38:47 PM by 754 »
Offline Johnny340
« Reply #84 on: August 06, 2018, 06:27:42 PM »
That is a k 6 of older swingarm.
Ok so that matches the K2 frame. And thanks to you I have a DOHC rear hub that works. The only thought is if that hub moves the driveline left a bit or not. Do I worry about trying to shift it 5mm right with custom spacers for better chain lineup or am I done here?
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #85 on: August 06, 2018, 06:32:18 PM »
When  you are looking at your sprocket alignment,  is the rear wheel semi snug and lined up to the marks ?
 Or Loosey Goosey ?
 If it's the last one, yes it can look way off.
Offline BPellerine
« Reply #86 on: August 06, 2018, 06:33:45 PM »
your chain should run straight,no matter what,if the swingarm is right and the sprocket holder is right,the only suspect left is the hub,if moving the wheel to get the chain in line causes the wheel to be out of line in the frame it might be an issue.bill
another anfob
« Reply #87 on: August 06, 2018, 07:40:48 PM »
Your Konis look like first generation.
 In case you don't know, they have ai think 7 internal damping adjustments .
 I can run you through the procedure, its hidden.
Offline Johnny340
« Reply #88 on: August 07, 2018, 10:40:59 AM »
Ok thanks for your help everyone! To put this thread to rest, I have it lined up perfectly with those spacers now that everything is tightened up. I put a straight edge along the chain line to check which tells all.
Frank I'll contact you regarding these shocks later. I'm trying to get this done for the 'vintage in the valley' show on the 19th.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline BPellerine
« Reply #89 on: August 07, 2018, 12:37:24 PM »
another anfob
