Author Topic: What is this wire?  (Read 513 times)
Offline Pwrwagontom
What is this wire?
« on: May 26, 2018, 12:31:39 PM »
Out for a nice memorial day/weekend ride today, and I spent a few hours broken down on the side of the road.  Appears to be an unrelated issue, where my metal key chain shorted on something in the ignition, blowing the main fuse.
Before I figured this out, I was going crazy, attempting to figure out where this loose ground wire goes, convinced that it rattled loose.
Obviously a ground, but I have nothing disconnected.  So...am I missing something?  The wiring diagram just says "ground to frame."
Should mention- this is a CB750K2.
Thanks in advance!
I'm going to print off a wiring diagram and keep it under the seat from now on...
CB750K2- Briar Brown Metallic
CB750K2
Offline rotortiller
Re: What is this wire?
« Reply #1 on: May 26, 2018, 12:47:06 PM »
Spare for flasher needing one I think.
    • http://forums.sohc4.net/index.php?PHPSESSID=fs2q9m0fdcmu8lfnb2uqngbd14&/topic,60973.0.html
« Reply #2 on: May 26, 2018, 12:50:18 PM »
yes for a 3 /vire flasher...aftermarked flashers is 2 vires...so the ground is not used,on those
Offline Pwrwagontom
« Reply #3 on: May 26, 2018, 02:39:24 PM »
That makes perfect sense!
Thanks guys- I'll tape this off.
CB750K2
Offline Kevin D
  • SE Michigan
« Reply #4 on: May 26, 2018, 03:25:17 PM »
Get the right length fuse in there, scuff the contact area with scotchbrite, check the rivets that hold the fuse clip to the wire terminal: all are contributors to heat at the fuse clips and random fuse blowing. Or get a modern blade type fuse and holder.
I see the green wire, harness-frame ground in the corner of your photo, just outside the circle.
« Last Edit: May 26, 2018, 03:30:23 PM by Kevin D »
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
