Author Topic: Honda cb350f regulator and rectifier replacement or upgrade  (Read 549 times)
Offline zcb350fb
I am just looking to see if anyone has replaced or upgraded their charging system’s regulator and rectifier? Did you choose to go with a replacement and keep the regulator and rectifier separate, just like it came from the factory? Or did you go with the new combined options?
As far as I can tell, mine is working fine. I’ve just been thinking about replacing them for good measure, being that they’re 45 years old
1973 cb350f
Re: Honda cb350f regulator and rectifier replacement or upgrade
« Reply #1 on: May 29, 2018, 11:36:13 AM »
Dont open up the vreg.  You'll let the 40+year old air out, which voids the warranty   ;D
If its working, leave it alone.
Spend the $$ on stuff that helps keep you alive.  Brakes, tires, suspension, better gear, etc.
...but yes, its been done.  Oregonmotorcycleparts and Ricksmotorsports make good products.
Offline zcb350fb
« Reply #2 on: May 29, 2018, 11:49:04 AM »
Haha thank you for the advice Flybox1
1973 cb350f
Offline carnivorous chicken
« Reply #3 on: May 29, 2018, 12:17:03 PM »
I'll second Flybox -- I haven't had any problems with 350F stock charging components, including a bike I've had for 20 years. Unlike some of the older twins I've had. If it ain't broke...
