Part 2: hub side (pictures attached):
- drilled Mark’s with a 1/8” drill bit approx. 1/16” deep
- used the same tool (though filed the screwed to make two flat edges (worked like a charm, did not need to apply too much force at all)
- pushed the spacer to make space, tapped (more like hammered on a screwdriver) and got the right bearing out (success!!! Did not take long, just patience.
- spacer with tabs fell out as well
QUESTION: are the tabs suppose be loose or snug to the spacer (would like to know so I can plan the assembly when all said and done).
... now working on the left bearing and I am stuck.
HELP/TIPS Needed:
I am trying very hard to push the left bearing out but having no success. It just seems jammed. What can I do or use to help move this sucker?
