Hi all -
I have a few follow (hopefully small questions):
#1: I ordered a new sprocket-side bearing retainer and an oil seal (to replace the old as they are in rough shape):
- 1.1 On re-assembly, are there any special instructions/things I need to do when a new bearing retainer (like re-tapping/re-staking the marked spots)?
- 1.2 Should I put loctite on the retainer threads? if yes, there are so many kinds, which one?
- 1.3 Should I apply grease to the seal when I put it into the retainer?
#2: I ordered a new o-ring (68x2.6) for the wheel hub. There seems to be are two distinct sides to it (threaded and flat).
- 2.1 What is the correct side out? I forgot to observe/take picture of which side is which.
- 2.2 Should I re-stake/tap the marked spots as well?
#3: aesthetics: the rim is in very good shape (very limited pitting or rust). The spokes are a different story - surface rust and they look bad. So, I started the cleaning process to remove the rust (using all tips and tricks off this forum) - and it is coming along very nicely. It will not sparkle, but it will not be rust either
- 3.1 ...so, I am thinking about applying a light clear metal coat on the spokes after I finish the spoke-by-spoke-time-consuming rust clean up side project- is this a good idea?
Thanks in advance
