I think it knows I have been planning to sell it (I have actually showed it to a few people).
First after I replaced the chromed valve cover with a freshly painted one along with the cover gaskets and pucks it developed an oil leak. Not long after that I started experiencing major overflows from multiple float bowls.
I bought some NOS Honda pucks, but when I got them an measure the depth of the shelf they sit on and compared it to the thickness, they just didn't seem thick enough. I had a spare set of aftermarket pucks and my caliper says they are thicker than the Honda ones, so in they went along with a little Hondabond. Hopefully that will fix the leak.
I picked up one new OEM float needle set the other day for a very good price and installed it last night. I ordered 3 more this morning, plus a gasket set (with shaped bowl gaskets) for all 4 carbs.
I started to ride to work today to see if the new pucks fixed the oil leak, and I am still having overflow issues. I have the overflow tubes routed to the outside of the engine so I can clearly see which carb is leaking while sitting on the bike. The #2 carb got the 1st OEM needle/seat and no overflow. But the #3 and #4 are both overflowing. Plus fuel is leaking from someplace else to and I didn't have time (and wasn't wearing clothes that could get dirty) this morning to figure out where. I just rode back home and got my car. I'll play with it some more tonight to see if I can pinpoint it.
I have 2 extra sets of 550 carbs. So if I have a cracked overflow tube or 2 I will just swap as needed.
